Evapo -rust for cleaning gas tanks.
Just curious if anybody has used this for cleaning a dirty rusty gas tank?
Re: Evapo -rust for cleaning gas tanks.
Also curious as in, is there a certain type of acid specified?
60-66 Nut
You can also use vinegar. Some people use rocks or a length of chain inside and rock the tank back and forth to help knock off the heavy rust.
You will want to neutralize it with baking soda water afterwards. Then dry it out, or add something like diesel to stop flash rust from forming
Thanks.Were these tanks coated on the inside from the factory?
#5 | |
I have used a couple of different sealers and have had great luck with them both. US STANDARD FUEL TANK SEALER POR-15® Fuel Tank Sealer was formulated and developed in our own laboratories due to the demand for a high-tech sealer impervious to all fuels, including the new Stage II fuels which have a high alcohol content. POR-15® Fuel Tank Sealer has superior strength and fuel resistance, and does not contain Methyl Ethyl Ketone, a highly flammable and deadly carcinogen (cancer-causing). POR-15® Fuel Tank Sealer is non-flammable and is environmentally safe. Formerly U.S. STANDARD FUEL TANK SEALER |
I used CLR and a pressure washer, I had excellent results.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
Muriatic acid and water works well. Lots of precautions to observe in its use and as above stop the rust from reforming because it happens quick.
