05-13-2016, 02:01 PM | #1 |
Clutch adjust, 66 250, 3 tree
Noticed they my clutch for rests on my frame.. Now with new motor it feels as if the clutch needs to be adjusted
Feels as if it's not releasing completely I have rod with V shaped end that rests in the clutch fork If I adjust it forward it will release it fully but will it slow it to engage fully? Or am I going to have to bend the rod to clear the frame? |
05-13-2016, 02:24 PM | #2 |
Re: Clutch adjust, 66 250, 3 tree
not sure I quite understand what your saying but pictures sure would help...
1964 BBC 402 4x4 |
05-13-2016, 06:50 PM | #3 |
Pics
05-13-2016, 09:13 PM | #4 |
is your truck a chev or gmc?
ron |
05-13-2016, 09:53 PM | #5 |
from your pic, it looks like your z - bar has slid over far enough that the linkage is hitting the frame. Their should be a snap ring in your z - bar assembly that holds the ball in position. Yours is missing or broke, allowing the side shift of your linkage.
If you don't like this pound sand ..... |
05-13-2016, 10:05 PM | #6 | |
ron |
05-14-2016, 02:16 AM | #7 |
Chevy
Doesn't seem like it's fully disengaging either So adjusting the rod just so before it touches the TB fork? The spring should keep it tight but I should have 1-2" of free play at the top of the peddle travel? It doesn't engage till almost the top Any diagram showing this exact clutch linkage? |
05-14-2016, 09:28 AM | #8 |
Your throw out bearing should have enough clearance not to spin when clutch is engaged. Best way to make sure is to remove inspection plate below clutch, then you will be able to see your free play. Here is a exploded view of clutch linkage:
