Old 05-13-2016, 02:29 PM   #1
chincha805
Steering shaft suggestion
what is the best way to go from
1"dd (steering column )
to
3/4" 30 spline (steering box)
chincha805 is offline   Reply With Quote
Old 05-13-2016, 02:43 PM   #2
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: Steering shaft suggestion
Something like this is ideal
http://www.summitracing.com/parts/brg-033152/overview/
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 05-13-2016, 04:51 PM   #3
1project2many
Factory steering shafts cut and welded?
1project2many is offline   Reply With Quote
Old 05-15-2016, 01:07 PM   #4
_Ogre
_Ogre's Avatar
no. no and again no
use the u-joint adapter
shop air compressor timer
Old 05-15-2016, 04:09 PM   #5
OrrieG
OrrieG's Avatar
Here is what I did for $10 (Astro Van shaft at junk yard). I had the 74 shaft from donor truck. U joints are not as elegant as Borgsen, but plenty strong. Retains slip joint for frame and cab movement (critical in my 4wd off road application) or collapse in collision. No welding except for spot welds after installing set screws treaded into the inner shaft.
Old 05-13-2016, 05:18 PM   #6
mr48chev
mr48chev's Avatar
I'm not a fan of the cut and weld idea as too many guys screw that up by doing it wrong.
The U joint setup that VS posted is a popular option but you can probably do it with stock pieces if you hunt a bit and use the DD pieces to adjust your length.
A couple of photos of what you are working with and what you need to do would go a long way towards getting a simple fix that didn't break the back and was totally safe.
My ongoing truck projects:
Old 05-13-2016, 05:37 PM   #7
chincha805
I kinda got the idea as to what to use, i cant make up my mind as to start from the 1"dd.
the shaft size is what i cant decide 1"dd shaft or 3/4"dd shaft. i know it is not that hard, but i dont want to overkill but not go smaller etc, you know what i mean.
Old 05-13-2016, 05:44 PM   #8
Valarius_Starchaser
An 800 series chevy 1500 would have the 30 spline side and a 400 series 1500 would have the 1 inch DD just install a quality U-joint (I dont like to go to cheap here) and you have that system I posted out of stock components for under 50 bucks with using a quality U joint
If you use some Chinese one it could bind and snap while turning.... No thank you
"Orange Crush"
Old 05-14-2016, 03:39 PM   #9
BIGglaSS
BIGglaSS's Avatar
Try mid '90's Jeep Cherokee from your local u-pull-it
BIGglaSS is offline   Reply With Quote
Old 05-14-2016, 06:03 PM   #10
joedoh
joedoh's Avatar
too short, I have one on the shelf.
I use borgeson u-joints and slip shaft
BRG-014931
Steering Universal Joint, Steel, 3/4 in. DD, 3/4 in. 30-Spline
BRG-015252
Steering Universal Joint, Steel, 1 in. DD, 1 in. DD
BRG-450036
Steering Shaft, Steel Alloy, Universal
the slip shaft is 3/4 on the lower side and 1" on the upper. no need to cut to length, its got a slip joint.
there are better places to be cheap than brakes or steering, in my cruddy opinion.
Old 05-14-2016, 06:14 PM   #11
Valarius_Starchaser
BRG-014931
BRG-015252
BRG-450036
Thanks for all the part numbers that just made my search a lot easier for my final setup
"Orange Crush"
Old 05-15-2016, 07:36 PM   #12
_Ogre
_Ogre's Avatar
i was robbed
had to fork out $25 for my astro van column
Old 05-15-2016, 08:34 PM   #13
OrrieG
OrrieG's Avatar
Originally Posted by _Ogre View Post
i was robbed
Got it in a bundle with a bunch of other parts, $50/5 = $10.
