Old 05-14-2016, 11:03 AM   #1
Matt Man
Matt Man's Avatar
k10 grinding noise
Well my truck is experiencing its first problem, I drive down the road and sometimes the right front makes a grinding sound, it only does it sometimes and if I slow down completely it goes away. I jacked up the wheel no play in the wheel bearing or balljoints and was professionally aligned to spec. Anybody have any clues to what it is?
Seems to be worse in the rain
Doesn't do it all the time
Can be felt in the steering wheel
Braking doesn't seem to effect it
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-14-2016, 11:08 AM   #2
TwoFiftyShifter
Re: k10 grinding noise
Could be a driveshaft universal joint. An easy fix.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 05-14-2016, 11:21 AM   #3
Matt Man
Matt Man's Avatar
I'm assuming the front? The rear was shortened and rebuilt last November. The truck also had manual warn hubs, but are about 17 years old.
Old 05-14-2016, 01:21 PM   #4
1976gmc20
Spindle bearing, maybe ???
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 05-14-2016, 03:25 PM   #5
CBR_Rob
I was tracking down a grinding sound for a couple weeks. Always heard it when turning then it would go away. Finally heard it with the Blazer parked on level ground looked all over and saw the sparks from the balancer hitting the front crossmember. Replied the motor mounts and no problems with the grinding noise after that.
CBR_Rob is offline   Reply With Quote
Old 05-15-2016, 05:56 AM   #6
wildwilly4x4
take the hub off and check the wheel bearing. Checking for up/down play just by jacking it up and grabbing the tire doesn't always show a bad bearing. Sometimes the caliper holds the rotor tight enough that you cant feel anything bad. If you haven't been into the wheel bearings in the last year or two, I would certainly visually check them. I repack the front about every 8-10k miles. sometimes more if ive been in deep mud or water. usually have at least one side that needs replacement.
wildwilly4x4 is offline   Reply With Quote
Old 05-15-2016, 09:46 AM   #7
Matt Man
Matt Man's Avatar
I repacked the front bearings a year ago when I first picked the truck up (the wheel bearings were loose). I will check them and report back here.
Old 05-15-2016, 10:37 AM   #8
barry1982
I had a similar problem a few years ago with my 82 . Turns out the manual locking hub on one side was not unlocking. My hubs were old as well, installed a new set of Warn hubs, and problem went away. Also repacked the front wheel bearings at the same time.
barry1982 is offline   Reply With Quote
Old 05-15-2016, 05:45 PM   #9
1976gmc20
Once you go in that deep, you might as well pull off the six nuts that hold the spindle and replace the needle bearing that supports the outboard end of the axle.
Old 05-15-2016, 06:56 PM   #10
wildwilly4x4
replace the spindle needle bearing with a plastic bushing from Longfield or RCV ( I think that's the ones making them now), much better design
