Old 05-14-2016, 05:46 PM   #1
WEBBY1
WEBBY1's Avatar
Idle/clutch issue
67 c20 v8. When i push the clutch in the motor revs real high. Truck hasn't been started in ten years
WEBBY1 is offline   Reply With Quote
Old 05-14-2016, 08:12 PM   #2
hamjet
hamjet's Avatar
Re: Idle/clutch issue
Could be a broken motor mount..watch the engine while you push in on the clutch.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 05-14-2016, 08:42 PM   #3
Alex V.
Alex V.'s Avatar
Yeah. '67 (throttle linkage, not a cable) might be affected by a purely mechanical interference. That or you've got something bad wrong in the clutch/tranny that's causing a lot of drag.
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 05-14-2016, 10:54 PM   #4
WEBBY1
WEBBY1's Avatar
Thanks ill try to get a better look tomorrow
Old 09-03-2019, 01:14 PM   #5
shane0331
shane0331's Avatar
Having a similar issue. Did you ever figure out the cause?
shane0331 is offline   Reply With Quote
Old 09-03-2019, 01:29 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
The OP hasn't been on the board since 10-07-2018 09:30 AM.
Does your truck have the throttle rod or cable linkage?
LockDoc
Leon
Old 09-04-2019, 03:10 PM   #7
shane0331
shane0331's Avatar
I know it’s an old dead thread. Thought it was worth a shot, he might get an email notification and reply.
My truck has a cable.
When I clutch in, (in or out of gear) the Rpms increase. I don’t have a tach, so I’m not sure by how much. I would guess 200-300 rpm increase from a clutch out and neutral idle.
Old 09-04-2019, 05:08 PM   #8
LockDoc
LockDoc's Avatar
That was a common problem with the linkage rod if the rubber motor mounts were separated or broken, but not so much with the cable. That's why they changed them over. I would still check the engine and bell housing rubber mounts and see how they look.
LockDoc
Leon
