05-17-2016, 04:32 AM | #1 |
71 longbed looking for exhaust
I live in southern Illinois close to StL
My truck has a 350 grate, edelbrock performer intake, 600 edelbrock carb. Need dual exhaust system that will sound great, perform great, allow wife and I to enjoy the ride. But also let people know we are coming, we are here and hear us when we leave. Been thinking flow master 40 or 44 with H pipe and dumping out before or after rear wheels. Looking for best price and advise on me installing the system with clamps or taking to someone to weld it together. What size pipe etc.... lay it on me with good solid recommendations. Also and video / sound clips would be nice. |
05-17-2016, 09:11 AM | #2 |
Re: 71 longbed looking for exhaust
Everyone has different opinions of what muffler to use, so I'll say try to get the mufflers under the bed and the tailpipes over the rear axle. It sounds better and moves vibration and noise farther back instead of right under that cab
'68 C10 SWB '85 K30 Blazer |
05-17-2016, 09:17 AM | #3 |
Thanks for that input. I am trying to find a kit that routes that way and I will clamp it together. Muffler shops around here want way to much to bend. /custom fit and weld.
05-22-2016, 09:29 PM | #4 | |
http://www.ebay.com/itm/Thrush-Welde...RW~q2h&vxp=mtr |
05-22-2016, 09:58 PM | #5 |
I used dynomax welded on my big block. Had 40 flowmasters dumped before the axle when I bought it , way to loud in the cab for me. Dynomax out behind the tires is perfect for this old teenager.
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
05-17-2016, 10:06 AM | #6 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
You can try these from LMC, http://www.lmctruck.com/icatalog/cb/full.aspx?Page=157
Or if you had headers you could go with one of the Thrush kits, http://www.thrushexhaust.com/ I've been using the Thrush Welded Turbo mufflers for several years now and like the low sound level and then it's game on when you step o0n it. I agree with what's been said, keep the mufflers under the bed and the dumps behind the the rear axle and drone will be kept to a minimum. I have two 72's, one SB and one BB, both have headers with "Header Back" systems I installed myself. Having a wire welder or a friend with a wire welder helps. I've also had good luck buying my exhaust pipe in 10' sections from the local muffler shop and have them put a series of four 45* degree bends in one end of one section and cut & fit them at home. That only works if you have a welder at home...~Ghostrider~
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
05-22-2016, 07:47 PM | #7 |
I'm looking for the same, currently I have 350 w/Ram Horn Manifolds and Glass packs (unknown brand) and it dumps before the axle), the sound is ok but the drone drives me crazy. Looking for a cleaner tighter sound and less drone. I will keep the Ram Horns put the mufflers under the bed and tail pipes out the rear I've been quoted $6-800 manifold back 2.5" pretty much any muffler installed. I'm thinking Flowmaster 40 Series Delta Flow or Thrush Welded. Good Luck
http://67-72chevytrucks.com/vboard/s...d.php?t=693490Cheyenne, AKA "Spare Change" Hack71 Build |
05-22-2016, 08:14 PM | #8 |
I am running a '72 LWB with a fresh 355/700r4, full length ceramic coated Hooker Headers, 3" stainless all the way out the back, with Thrush turbos tucked under the bed in front of the axle, exits under roll pan for now, but i am going to change the tails to dump like a COPO camaro did behind the wheels.....
Also plan to add an X pipe before the mufflers... |
05-24-2016, 04:26 PM | #9 |
I just had mine redone after my suspension overhaul. I have a 350 crate engine with new Heddman mid-length headers and I reused my 40 Series Flowmasters. I installed the headers and had a local exhaust shop run new 2.5" pipe, tucking it as high as possible, and dumping right before the rear bumper. I also had them add an h-pipe before the mufflers. They charged me $290. This gave my truck an aggressive, muscle-car sound on the outside, but it's very tolerable inside the cab. In fact, my 2 year old son was kind of bummed that it wasn't as loud anymore. (The exhaust was dumping right before the rear axle housing and the drone was miserable inside the cab in low RPM's.)
1969 Chevy CST/10 396, PS, PB, A/C |
05-24-2016, 04:30 PM | #10 |
Let's try this again. Here's a couple pics.
05-24-2016, 05:31 PM | #11 |
My dad had glass packs installed with pipes angled to the sides of the bed just in front of the rear wheels. I did not like the sound exiting each side, stopped by a muffler shop and for $150 they put 2 of the largest mufflers they had with dumps in front of the rear axle. Sounds way better, is quieter but still fairly loud outside of the cab.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
