05-20-2016, 01:07 PM | #1 |
Anyone use the automatic car wash?
Anyone use the automatic car wash with the spinning brushes with our trucks? I fear that it might damage my mirrors. I have the stock stainless mirrors with the triangle base.
05-20-2016, 01:40 PM | #2 |
Re: Anyone use the automatic car wash?
I would never take your truck through an auto wash that wasn't touch less!!! I would fear the brushes or pads would grab ahold of your mirror! I once took my '15 Ram 2500 through and it grabbed my side view and flipped it to the forward position.. It also broke off my antenna and bent my license plates.. My bad for not removing my antenna, but these things are harsh! May be fine for smaller cars or the sort... Never again!!
05-20-2016, 01:46 PM | #3 | |
Thanks |
05-20-2016, 04:44 PM | #4 |
I wouldn't. I value my truck too much to put it through that....
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-20-2016, 04:49 PM | #5 |
I have a bigger problem here in Burbank CA. It is now illegal to wash your own car in Burbank because of the drought in California. I don't know what I am going to do after I get my truck back from paint.
05-21-2016, 12:18 AM | #6 |
60-66 Nut
You will probably have to resort to something like this.
http://www.dwginternational.com/WebSite/DWG.shtml I have a friend that is a distributor for their products. He swears by their products and uses them all the time. Here is his website. http://www.marksdwg.com/
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-21-2016 at 12:24 AM. |
05-21-2016, 08:32 AM | #7 |
If you used the bath water you can wash your vehicle...you need to take a couple of digital photos to prove it...our son did this and the neighbor freaked out...he showed them the photos and the guy said it was a great idea and immediately washed his car...after he took a bath...just saying...Marla
05-21-2016, 07:27 PM | #8 | |
That is hilarious
05-20-2016, 10:20 PM | #9 |
I wouldn't take a junk car through an automated car wash, much less one I actually cared about.
05-20-2016, 10:29 PM | #10 |
Ditto. I despise them things. Chemicals are so harsh to be touch free even. I'm out on that.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
05-21-2016, 08:28 AM | #11 |
Never...had my antenna torn off plus one wiper blade
05-21-2016, 08:33 AM | #12 |
Never. Not on any of my cars, and even though my old truck's paint really is done for, I still wouldn't take it through one. As said above, too many chances of ripping something off. For my cars, I would be concerned I was running through right after some kid got back from mudding in his truck, and the brushes would be hiding all sorts of grit and scratch up my car. That may or may not happen, but I haven't seen the need to risk it either.
1965 Chevy C10 Stepside Shortbed--2012 370Z Base Gun Metallic--2020 Chevy Silverado RST Crew Cab |
05-21-2016, 10:17 AM | #13 |
I second the dry wash motion if you can't use water. We use a product called No-Wet on our helicopters and the stuff works surprisingly well I have to admit. U experiment with a lot of different cleaners in my profession trying to find the one that works the best, the fastest, and the cheapest. Top two degreasers-- purple power and aircraft extreme simple green (this stuff in truly amazing). I also like using acid on very soiled paint, chrome, and aluminum.. Phosphoric acid works great on stainless.. It's amazing how it eats the rust and other corrosion . You can see the before and after of the acid bath on my build thread. No scrubbing, spray on spray off. And between washes try some McGuires quick detailer.. The stuff in the red bottle. Not the new black one. Works well to keep the paint clean and from attracting the dirt. Little off topic but maybe someone finds it useful
http://67-72chevytrucks.com/vboard/s...t=Corvette+327 http://67-72chevytrucks.com/vboard/s...d.php?t=704329 |
05-21-2016, 03:40 PM | #14 |
I admit to it. We have one down the road from my work. Get corp discount too. They use a neoprene set of brushes that are softer than the normal nylon. I see black BMW's, Caddy's, Benz's come out looking fine. My well water is so hard that even after the biggest softener you can buy - it still leaves etching spots. So any way the car wash guy has to hold up the top roller brush when i go thru. the first time the brush got stuck on the sun visor over the windshield and they had to stop the line to come get me. Other than it works good. even a wheel brush for the white letters.
--Life looks better through a curved windshield-- |
