Old 05-20-2016, 01:12 PM   #1
IHutch5R
Who out there has front disc brake/drop spindle conversion with 15" wheels???
I finally have the money to do the disc brake/ drop spindle conversion. All the kits I'm looking at though say "may not fit with factory 15" wheels." If you have thus setup please let me know what kit you got and what I need to be aware of. Thank you
IHutch5R is offline   Reply With Quote
Old 05-20-2016, 02:09 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Who out there has front disc brake/drop spindle conversion with 15" wheels???
That disclaimer is because the 60-70 6-lug oem steel wheels don't clear the disc brake caliper.
Any aftermarket or oem 71-87 6-lug wheel will work fine.
Keith
Convert to disc brakes.
Old 05-20-2016, 02:33 PM   #3
IHutch5R
Thank you. On a side note.. I'm looking at this kit from CPP.. any input would be awesome.
1960_1972_Chevy_Truck/6370SWBK5S.htm
Old 05-20-2016, 04:31 PM   #4
lolife99
lolife99's Avatar
If you are going to go with CPP buy from someone like Summit Racing that offers FREE shipping.
http://www.summitracing.com/parts/cl...d/applications
Keith
Old 05-20-2016, 04:37 PM   #5
IHutch5R
Thank you, are there any kits you'd recommend over the CPP?
Old 05-20-2016, 04:34 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
Also, some of the original wheels will actually fit and work on the disc brakes if the center section of the wheel is skinny enough. I ran several original 3 hump wheels and a pair of original mags up front for quite a while without trouble. They either fit, or they don't.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-24-2016, 02:59 PM   #7
reed62
reed62's Avatar
I bought some 73-87 15" 6 lug rally wheels at a swap meet and the rear wheels are a pretty snug fit over the axle. Not sure if anyone else ran into this or not.
reed62 is offline   Reply With Quote
Old 05-20-2016, 04:38 PM   #8
Clyde65
Clyde65's Avatar
I have CPP drop spindles and disc brakes ( 71-72 C10) on my 65, I use 5lug Rallley wheels, 15*8', until I put the drop springs, 2" and then I went with 15*7 Ralley wheels.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-20-2016, 04:41 PM   #9
forestb
forestb's Avatar
Are you looking at the drop spindles or regular and are you planning on getting the modular or regular spindle. I have had modular and regular drop spindles for my 62. I had a set of 15 inch rally wheels from wheel vintigues. The regular drop spindles worked the modular drop spindles did not. You will need a larger diameter wheel if you want to use the modular spindles. I could not use your link that is why I am asking.
forestb is offline   Reply With Quote
Old 05-20-2016, 04:43 PM   #10
IHutch5R
Okay, yeah I still don't know the difference between modular and regular.. haha I assume it's regular and yes the 2.5" drop spindle.
Old 05-20-2016, 05:04 PM   #11
forestb
forestb's Avatar
When you convert to disk breaks the wheels gets pushed out. The modular spindles are supposed to prevent that and they allow you to install a larger caliper if you want it.
Old 05-20-2016, 05:14 PM   #12
IHutch5R
Which ones would.you suggest then? Do you know how much they get pushed out?
Old 05-20-2016, 05:17 PM   #13
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
forestb,
What was it about the Modular that didn't work for you?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 05-20-2016, 05:45 PM   #14
forestb
forestb's Avatar
I like the modular and still have them on my truck. The only problem was when I tried to put my 15 inch rallys on them they would not fit. I am not sure how much the regular spindles push the wheels out. Not enough to bother me and I have 275's up front. The only reason I switched from regular to modular is because I installed a 1977 front clip and I needed new drop spindles. The regular ones I bout for my 62 are just sitting around. Also I think the modular spindle give you a 2 inch drop while the regular have a 2.5 inch drop.
Old 05-20-2016, 07:19 PM   #15
IHutch5R
Thank you, this is the Intel that I needed. I feel better about making a purchase now.
Old 05-20-2016, 08:55 PM   #16
The Rocknrod
Moderator
The Rocknrod's Avatar
I have a Western Chassis drop spindles and Disc brakes. I went to the wrecking yard and got two 5 lug 15" steel wheels off the front of a chevy truck. They fit. What year I cant tell ya.
Old 05-20-2016, 09:27 PM   #17
LostMy65
LostMy65's Avatar
I don't want to hijack this thread, but I do think it's related to the topic.
This question is for Chevy_mike.
You posted this in another thread.
Do you remember what the backspace was on these wheels you posted about?
Originally Posted by chevy_mike
A happy side note for those wanting to run 15x8" rally or stock style wheels and typically have clearance issues with the lower A arm lip, around the lower ball joint, these give you enough clearance to not rub or require you to trim the A arm (which I don't like). Here is a pic to show the clearance and I did cycle the steering from lock to lock and no issues anywhere.
Old 05-21-2016, 11:35 AM   #18
IHutch5R
Does that clearance apply for just the wheel or does it not clear the brake also??
Old 05-21-2016, 12:00 PM   #19
LostMy65
LostMy65's Avatar
Yeah, these are Modular Drop Spindles with only a 2" drop. If they weren't Modulars, they wouldn't be pulling the wheels in so close to the A-Arm.
Old 05-21-2016, 12:02 PM   #20
IHutch5R
Got it.. thank you.
Old 05-23-2016, 09:48 AM   #21
robber grin
Bell Tech Drop Spindles and CPP Coils on a 78 burb clip on my 62
Running early (70's) Chevy 4WD 15" rims
Drop brackets for sway bar, relocated shock brackets on frame and relieved the lower A arm to clear the wheels
robber grin is offline   Reply With Quote
Old 05-24-2016, 12:15 PM   #22
IHutch5R
Thanks everybody for the help and input.. I got my kit ordered and should have it by the end of the week. Will post before and after pics. Also, thanks for the tip to order from Summit.. I saved about $200 on shipping that I can put towards new wheels.
Old 05-27-2016, 03:12 PM   #23
Dawgtraxx
Did the cpp conversion on my 63, went with 16x8 wheels with 5" back spacing, had to grind a little off the spindles because wheels hit
Dawgtraxx is offline   Reply With Quote
