05-22-2016, 08:35 PM | #1 |
How wode can you go ?
Question is how big of a rear tire can you run before you have to widen the wheel wells ?
05-22-2016, 08:38 PM | #2 |
Re: How wode can you go ?
Step or Fleet Side?
1970 C10 Short Stepper with 71/72 front clip. |
05-22-2016, 09:58 PM | #3 |
1/2T or 3/4T?
Which rear end? Leaf spring or coil spring..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
05-22-2016, 10:29 PM | #4 |
1/2 ton fleetside
05-22-2016, 10:34 PM | #5 |
A couple other things are the early narrow housing or the wider later housing wheel offset will also factor in. I've got a deep offset 5.75 with a 50 which is about a 9.5" wide and have less than a 1/2" from rubbing on the inside when tucked and aired out.
05-22-2016, 10:45 PM | #6 |
I have the narrow housing, so I assume that probably would make it worse..
05-23-2016, 07:59 AM | #7 |
I just went thru this.
The widest tire I could have fit without cutting anything was at 28x12x15. Only reason I didn't is because they didn't come in the style I wanted. I ended up with a 275/55/15 on a 15x10 with 4.25 BS. I have a 67, so mine is the narrower axle according to this site. |
05-23-2016, 08:30 AM | #8 |
Narrow axle only affects the backspacing of the rim. It won't affect tire size.
05-23-2016, 08:32 AM | #9 |
I'm running a 20x10 with 5.5" backspace. Tire size of 295/45-20 which is 30.45" tall. Total of 8" static drop on the rear and have no rubbing issues at all.
Mike |
05-23-2016, 09:42 AM | #10 |
This is all irrelevant information as it will be dependent upon what rim you run (offset/back spacing) if you want to know the width you have to work with go measure from inside your rear tub, from side to side and you will have your number, from there it's a matter of finding the right wheel to maximize that space, you can go into 300 series tires with the right back spacing.
1972 C10 - It might be old, but it's not slow |
05-23-2016, 10:46 AM | #11 |
That sounds like a reasonable explanation. But i do not have the truck assembled
