![]() Join Date: Feb 2009
Door components removal, such as for the roll-up window
Lots of information on this website, but I could use some clarification/confirmation. I'm removing everything from the doors "next week" (Sure hope it doesn't take a week HA!). It would be a very bad day to break a window. I've already removed the inside door panels and door locks. Sorry for all the questions, which are in blue font. My primary concern is how to remove the roll-up window and regulator. Thank you for any comments/advice:
Should I remove the door latch and door handles before the windows? The inside door handles are on without the interior panels in place. There appears to various approaches, but would you agree the roll-up window should be removed before the vent window? Is the window channel the felt piece that runs from the top of the roll-up window to inside the door to the vent window? I’ve read from various posts to “remove the rear window channel”. What is this? The following seems to be the best instructions I've found (thanks LocDoc). Any comments or additions? 1. Remove the inner and outer window sweeps. (You can’t pull the wing window back to get it out of the door frame with them in place). 2. Pull the door window channel out of the door frame at the top by the wing window. (You can’t pull the wing window back to get it out of the door frame with it in place). 3. Remove the two ¼” machine screws at the bottom of the "rear" window channel and the ¼” machine screw from the top of the "rear" window channel by the door latch. You can leave the channel in the door but push it back in the corner. 4. If you are replacing the window felt channel pull it all out starting up by the top of the wing window. 5. Roll the door window down and slide it back away from the wing window. Does this mean the window should be raised all the way up for the steps 2 through 4? Can the window be removed at this point? I'm not too concerned about removing the vent window. From what I can tell this should be pretty simple if the roll-up window is removed first. Thank you.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
![]() Join Date: Jun 2005
Re: Door components removal, such as for the roll-up window
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Power windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
#3 | |
The Older Generation
Answers between questions (in Black type).
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 05-24-2016 at 02:06 PM. |
In my notes for my teardown on my frame-off, I have a little margin note ala Fermat that the shop manual actually provides good and useful steps for this. Which is not my way of saying RTFM, just HALATM.
(Have a look at the manual) if you have one. It helped me in this case! Here were my steps, for what they're worth: Remove outside mirrors Remove driver's door panel Remove window regulators and lock hangles Remove vent windows Remove main glass from doors Remove regulators from doors Unclip 2 rods from each door latch Remove latch Remove pull knob from lock rod Remove handle rod and armature Remove door handle Remove chrome strip from inside of door Remove Custom Camper emblems from doors Remove cowl to cab seals Remove door with hinges still attached to doors Remove door strikers - count shims
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
I'll let you know how it goes. Thanks a bunch for the responses.
![]() Join Date: Apr 2005
Great info!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Pulled my vent window out. It's real simple and not a lick of rust. I had more trouble with the sweeps. I'm removing the components from one door at a time, so the next one is easy.
I've read where some had trouble clearing the vent window from the roll-up window. That's simply a case of the window not being pulled back to the rear door (thanks doc). It should come out smoothly and not contact a thing. The only jiggling I did was to loosen the vent out of the corner. Here's an excellent video. The second video (6th post down) isn't quite as good IMO, but it works. https://www.youtube.com/watch?v=JGMKPuS1NJQ http://67-72chevytrucks.com/vboard/s...d.php?t=423022
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 05-29-2016 at 03:38 PM. |
Though I appreciate a thread referenced above, I don't believe it's quite correct. You roll the regulator up above the bottom of the window frame, then slide the window out of the regulator. Just like the guy did in that "second video" per my last post, only there's no reason to use the tool he's using to do it.
I bumped this thread hoping for some suggestions. I figure I can sleep nights using OER window regulators if they're made well. Any suggestions for good quality? Also, for years I thought my felt channels had broken off near the top front of the window frame. Turns out the felt wasn't glued onto the bracket for the RH door. Should it be? Should they have been glued on from factory? I haven't gotten to the LH door yet, but I think it's safe to say it's not glued on either, beings 8"-10" of it are laying on the bottom of the door. ![]()
#9 | |
I can't help on the regulators. I have never glued my felt channels in, they have always fit tight enough to stay in. I also don't recall having taken one apart that was glued..... LockDoc
sub'd.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. ![]() |
Thanks doc.
