05-25-2016, 02:10 PM | #1 |
TH350 vs TH400 Mounts
Do the TH350 and TH400 share the same transmission mount (rubber block at the crossmember)?
I'm replacing the transmission mount for my TH350, i have the mount bolted to the transmission, but I'm having a hard time getting the crossmember bolt holes to line up. Maybe I have the wrong mount?
Nick 1972 Chevrolet C10 Stepside |
05-25-2016, 02:30 PM | #2 |
Re: TH350 vs TH400 Mounts
This style is: Designed to work with Powerglide, TH-350, TH-400, 700R4, and all Borg-Warner, Muncie, Saginaw, Chrysler 4-speed, and Doug Nash 5-speed transmissions.
My Build: 57 Chevy Pro-Street |
05-25-2016, 02:38 PM | #3 |
I've seen that one a few times while googling this question. The mount I have only has two holes on the crossmember side instead of the three shown above (no hole in the middle). Maybe I just need to push the transmission until the holes line up... not an easy task when laying on my back underneath the truck!
If I still had the old transmission mount I could compare the two, but the old one literally disintegrated
05-25-2016, 02:41 PM | #4 | ||
"I ain't nobody, dork."
They are the same. Don't worry about the 3rd hole for the TH350 and the TH400.
Put a 12" by 12" piece of study plywood (3/4" or so) and put it on your floor jack and then support the transmission by the pan. Let hydraulics do the work for you. Gary
05-25-2016, 02:51 PM | #5 |
Also loosen up your crossmember and get all the bolts started before you tighten anything up.....
You may want to 'open' up the holes on the cross mount a little, just because if the rubber is under stress when it is all tightened up it will just wear out again really fast....
