What is the color of my interior??
Would someone let me know what is the color of my 1970 CST Longbed interior? I was fortunate to have you guys educate me on the color code and paint scheme for the truck and now I need to know what color the vinyl interior is. It states that its green....but. I need to order a couple parts and the carpet and don't want to get the wrong stuff. See the attached pictures. The overhead light in the garage makes it look a bit different than outside...... thanks in advance.
Re: What is the color of my interior??
The flat green of the upper forward dash under the pad is Ditzler 44224.
The painted parts of the column and such are Ditzler 2205. The vinyl and plastic parts I don't recall being reproduced in that '69-70 green. You might have to dye it with a product like SEM sells. Best bet is to compare product samples to know original color parts on your truck. The bottom of the dash pad and carpet from under the seat should give you good references as well as the door panel's back side. Just remember the the colors are going to be close but not an exact match on the original parts. Probably five or six different greens make up the interior parts collectively between the painted, hard, soft and vinyl plus the carpet.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Thanks Tim, appreciate the paint codes. Does anyone have this color interior that ordered replacements??
SWB 4x4 Collector
![]() Join Date: Jun 2001
Try classic industries for aqua interior parts. Worth a shot. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
