Old 05-29-2016, 08:02 PM   #1
Tod59
Bed bolts: Where?
Hey guys,
Working on the bed of my 59 short fleetside, replacing all the wood and new polished stainless strips. I ordered a new stainless bolt kit, all carriage bolts are there but my question regards the 1/4-20 and 5/16- carriage bolts, there are a lot of them but......I'm not sure which holes take the 1/4-20 and which holes take the larger size?
I tore all the old bolts out thinking the new kit would have detailed instructions as to where each size would go. Lesson learned on my part. No instructions included.
Anyone have a diagram where the different sizes go? I know the six long 3/8 bolts go through the wood and frame.
Tod
Tod59 is offline   Reply With Quote
Old 05-30-2016, 01:18 AM   #2
mr48chev
mr48chev's Avatar
Re: Bed bolts: Where?
I'm thinking that if you check the 5/16 will go along the ends of the bed strips while the 1/4 will run down the rest of the way.
Count out the different sizes of bolts and count the holes and go from there.
I'd guess there are about 18 5/16 bolts in the kit to
My ongoing truck projects:
Old 05-30-2016, 09:32 PM   #3
_Ogre
_Ogre's Avatar
all of my bed strips were punched for 1/4'' bolts, i used no 5/16 bolts on the bed strips
shop air compressor timer
Old 05-31-2016, 03:55 AM   #4
MiraclePieCo
MiraclePieCo's Avatar
On a Ford PU on which I replaced the wood kit, the larger bolts went on the ends of the boards and the smaller ones were in between. Since this agrees with mr48chev, it may apply to Chevys as well.
MiraclePieCo is offline   Reply With Quote
Old 05-31-2016, 11:13 PM   #5
my56chevytruck
my56chevytruck's Avatar
the 5/16 goes along the outside thru your L angle bed strips and the 1/4 goes thru the bed rails. the holes in your strips will tell you what size goes where.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 06-01-2016, 01:03 AM   #6
mr48chev
mr48chev's Avatar
It's been 40 + years since I bolted bed strips down in my truck so I am no doubt off on that part.
On the 1/4 inch bolts the longer ones will go at he ends or in the cross rails and the shorter ones will use a washer under the wood between the cross rails
Old 06-01-2016, 09:54 AM   #7
Tod59
Thanks to all that responded!
