06-04-2016, 10:44 AM | #1 |
stabilizer bar install from a 80's check to a 71
Hello all, I am installing a front stabilizer bar from a 86 3/4 ton chevy to my 71 custom 10 1/2 ton chevy. The question I had is do I need to jack up the frame so the a - arms come down to pit it on or put it on while it's sitting on a level surfce. I have to drill the holes to put the hold downs on it too. Any advice would really help. Thanks in advance.
IronX |
06-04-2016, 11:12 AM | #2 |
Re: stabilizer bar install from a 80's check to a 71
On a level surface, on the ground or have your truck on ramps.
06-04-2016, 11:23 AM | #3 |
i had enough room under mine (factory ride height) to install while sitting at normal ride height, no ramps or jack required.
It builds on my intelligence when I make a mistake, Boy am I building on it! '67 C-10,'70 Nova SS |
06-04-2016, 01:32 PM | #4 |
70+ ( Old Skool Club )
You will love the difference in handling with the sway bar installed.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-04-2016, 02:07 PM | #5 |
Yes you will actually enjoy on/off ramps ! LOL!
06-05-2016, 12:48 AM | #6 |
So I just drill new holes for the sway bar u - clamps and neoprene bushings? 2 on the front and 1 set on each lower a-arm. Has anyone ever done one like this? Tho ones on like I see have that long bolt holding it on each lower a-arm and I have that big flat U-band holder with neoprene bushings. Thanks guys I really appreciate all the input!
IronX |
06-05-2016, 02:16 AM | #7 |
Here's an old thread with lots of good pictures and information:
http://67-72chevytrucks.com/vboard/s...ad.php?t=72338 |
06-05-2016, 10:30 AM | #8 |
Thanks cast iron I appreciate it! Have a nice day
06-05-2016, 01:31 PM | #9 |
You shouldn't have to drill any holes.
