06-05-2016, 02:13 PM | #1 |
Fender Dually Question
Hi,
My driverside fender is damaged, but how can I remove this fender???? There are no bolts or not visible. Anyone can help me out? |
06-05-2016, 06:25 PM | #2 |
Re: Fender Dually Question
The bolts should be visible inside the dually fender, attaching to what was the pickup box outer panel. The original wheel opening was trimmed and a piece of angle reinforcement added. The bolts protrude through that angle structure.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
06-06-2016, 05:55 AM | #3 |
Next!
Replacement before and after shots
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
06-06-2016, 04:39 PM | #4 |
OK thanks; I can do that
06-07-2016, 01:04 AM | #5 |
Sometimes the studs mounted in the Fiberglass will break free and turn . Then you have a b"@&$h of a time getting them off . Take some time to clean and spray the threads with a penetrant so they don't break out and turn in the fiberglass fender. A little patience and prep( a few sprays and a couple days to soak) will really aid the process.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
06-10-2016, 11:11 AM | #6 | |
I will do that too.... |
