06-09-2016, 10:01 PM | #1 |
Has anyone ever replaced this a/c compressor clutch?
Like the title says, I'm wondering if anyone has actually removed/replaced just the a/c clutch. Is it doable with the compressor on the truck? What tools are needed? I looked in my factory manual and found zilch, searched on here and found nada, so I figured start a post so maybe the next guy will have some info
I do not want to open up the a/c system bc last year I replaced every piece of the system and am extremely happy with the results other than the chirping clutch when it kicks on that started about two weeks ago. What sucks is that I bought a new (not reman) delco compressor so I wouldn't have any problems... Enough ranting. Thanks in advance for the help |
06-09-2016, 10:13 PM | #2 |
Re: Has anyone ever replaced this a/c compressor clutch?
I had a boss that did it once. Had to make a tool to pull the clutch off the shaft but it is doable.
06-09-2016, 10:34 PM | #3 |
18 Till I Die
Yes there is a special removable/install tool we had at the dealer...If you have the tool, remove shroud and it is accessible without draining the system. Just take notice of the gap before removal.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
06-10-2016, 06:23 AM | #4 |
Moderator
Yes.
You need the removal and installation tool and you need to make sure the air gap is correct. https://www.amazon.com/COMPRESSOR-CL.../dp/B00G1RXGCU The GM service manuals have the procedure. Look in my signature...
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
06-10-2016, 01:37 PM | #5 |
Looks easy enough. I think that's what I'll do. New tool time! Lol
Thanks guys. |
06-10-2016, 03:14 PM | #6 |
Check your clearance first. You might just need to adjust the clutch. This is easy to do, and O'Reilly has the tool you can "rent". I usually set the clearance between .015-.020 inch. Here is a link where a guy shows how it's done. https://www.youtube.com/watch?v=Hqp9IJ2ivl4
If you do have to replace it, the same tool set does the job. Mike
All things Chevy truck: 1986 SWB "Jolene" boosted 5.3/4l80e project |
06-10-2016, 04:56 PM | #7 |
Just to ask the stupid question, ANY chance it is a slightly loose belt? That was my first thought when I read 'chirping clutch'.
06-10-2016, 07:09 PM | #8 |
I felt that the belt was too tight already, but to make sure I just snugged it up a touch more and it's still chirping.
I think if I have some forward wiggle room when putting the new clutch on the compressor shaft then I'll leave it out a little to help line the belt up with the water pump and crank pulley a little better. |
06-13-2016, 11:42 PM | #9 |
Just an idea but wouldnt a worn or dried out belt cause that noise also.I'm assuming that it is a serpentine belt. If it were me I would try a new belt before I tore into the AC compressor. If that doesn't cure it then you have a spare belt. Just saying.
06-14-2016, 12:38 AM | #10 |
Good suggestion. I'm running v-belts still though and replaced the belt with a new one when I put the a/c on last year. However I'm not sure how well I like the gates brand belt I'm running just yet.
06-14-2016, 12:43 AM | #11 |
Just read on another GM forum where the gap between the clutch and the pulley had tightened up and was chirping.
Most GM compressors close the air gap between the clutch and the pulley because the clutch is pressed on. All you have to do is increase the air gap with the proper tool and that’s the ens of it. But no on the other forum the guy was told to replace his clutch and purchase an expensive AC Compressor service kit that he will probably never use again. After spending lots of money his new clutch is not chirping and he is a real AC technician. But I am stupid so spend away.
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
