Old 06-10-2016, 11:49 AM   #1
jskeezy84
looking for advice on A pillar rust on a 63.
I started stripping to bare metal to see where my problem areas are and it looks like ive got a good bit of rust in the A pillars on both sides of the truck and along the top door jam. Of course the floors are shot too but there is at least repo part for that. The A pillars on the other hand I have not been abke to locate an aftermarket alternative, and even if i could I'm more than certain they are crap. So I am looking for advice on how I tackle this. I have looked around for cabs in my area to maybe cut the roof off but they all have the same rust, the Midwest sucks for that.
My idea is to brace the crap out of the cab, cut out the entire top door jam and weld in some smal patches piece by piece instead of cutting out large chunks and potentially loosing the correct shape. Anyone seen any write ups on this kind of repair? I should also mention that it is my plan to pull the roof skin and clean up inside there, seal it with por15 and dynamat so with that in mind should I pull the roof skin first to allow better access to this rusted A pillar section?
https://drive.google.com/file/d/0B6f...w?usp=drivesdk
jskeezy84 is offline   Reply With Quote
Old 06-10-2016, 03:29 PM   #2
canadian_diesel1964
Re: looking for advice on A pillar rust on a 63.
I had found the same rust in my 63.. I was lucky enough to get another cab....and even then there is work to do...if your going to keep it its cut and patch man...sorry there's no easy way out...you've got the right idea but the best is to cut out only what's bad...I'm not an expert on pulling the roof..but others will chime in....good luck bro
canadian_diesel1964 is offline   Reply With Quote
Old 06-10-2016, 09:19 PM   #3
62 Barnfind
62 Barnfind's Avatar
I had the same problem on the 58 i'm working on. The owner bought a donor cab for me to cut off of to fix the rust around the roof area. I could have done it with flat metal but it would have taken a little longer. It's really not that hard to do. What ever you cut off just trace it to flat metal and grind and weld it into place. I had the rust on both sides and the front of the roof on the 58. Pulling the roof is a good idea. I wish I would have done that. It makes the repair much easier and you can seal up the roof. Clink on the link below from orange to ? if you wan to see more pics. I hope this helps.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
