Old 06-12-2016, 04:26 PM   #1
solidaxel
solidaxel's Avatar
Oil Pressure alarm 5.3
Left the house this AM and when I got to the stop sign turned the corner the alarm and dash reads oil pressure? and the gauge is fluctuating down from 80 to zero.
Checked the oil and the dip stick says FULL
any suggestions?
The truck is stock with 80K miles
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-12-2016, 08:04 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Oil Pressure alarm 5.3
analog or digital OP gauge? Check your sender or oil feed. If the gauge is correct, then it might be the oil pump o-ring.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-12-2016, 10:57 PM   #3
solidaxel
solidaxel's Avatar
The analog gauge (dash) was fluctuating, I will try a additional analog at the oil filter bypass first.
What is the color of the good O ring if I need to replace it?
Thanks Br3w
LS 3 4L70E
Old 06-13-2016, 12:40 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If its using the 1/8 nylon line, it might be kinked or has air in it. Mine had a slow weep when the oil got hot and would piss a little bit of pressure and make the gauge go goofy.
O-ring depends on which pickup your using.
Old 06-13-2016, 07:04 AM   #5
ls1nova71
ls1nova71's Avatar
Is this a stock '99-'07 Silverado? If so, the oil senders are known for going bad.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 06-13-2016, 02:29 PM   #6
solidaxel
solidaxel's Avatar
Thanks,
I' m off looking for a new sending unit
LS 3 4L70E
Old 06-13-2016, 09:24 PM   #7
ls1nova71
ls1nova71's Avatar
I have personally never seen an oil pump O ring just go bad, they are usually only a problem if they've been taken apart. I have however seen many sending units go bad and leak oil. That said, if the gauge is stuck on 80, it could be the stepper motor for the gauge that is bad, they're notorious for going bad too, and although not as easy to replace as the sender, they are not really that hard to change either. I would start with the sender if it were me though as I don't think a bad stepper would trigger the low oil pressure message on the dash.
Old 06-13-2016, 07:59 AM   #8
solidaxel
solidaxel's Avatar
Well I guess I will start with the aux. oil pressure gauge and see if it is reading correctly.
The stock oil pressure gauge does not look like it will be fun to replace!
The truck is a stock 03 1/2 ton 5.3 with 80K and it has been well taken care of.
The oil and filter have about 1000 mi since a oil change and the filter is a Wix.
I am leaning towards the "O" ring, but I will know soon!
I am going to pick up a "O" ring this AM, what color is the "good" one???
LS 3 4L70E
Old 06-13-2016, 08:05 AM   #9
solidaxel
solidaxel's Avatar
If I unhook the sender it will set the alarm correct, is there a procedure to test the sender besides R & R?
LS 3 4L70E
Old 06-13-2016, 01:06 PM   #10
solidaxel
solidaxel's Avatar
I hooked up a Aux. mechanical gauge and it reads 42# at idle with a increase in RPM's it goes up to 50# and the dash reads 80# all the time, so I'm gussin start with the sending unit!
LS 3 4L70E
Old 06-14-2016, 01:44 AM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Once the steppers go bad, don't they just stop dead? Oddly enough all my GM vehicles either have good luck, or aftermarket gauges lol.
Old 06-14-2016, 08:34 AM   #12
solidaxel
solidaxel's Avatar
Just tried it this AM, I do not think it was the Oil pressure gauge as it still sets the alarm low pressure!
I am going to attack the "O" ring, what color?
LS 3 4L70E
Old 06-14-2016, 07:22 PM   #13
ls1nova71
ls1nova71's Avatar
You tried the sender and it still didnt work?
Old 06-14-2016, 09:38 PM   #14
solidaxel
solidaxel's Avatar
This AM the Low Pressure alarm went off so I am going after the "O" ring on the pick up tube
LS 3 4L70E
Old 06-15-2016, 08:02 AM   #15
truckdude239
truckdude239's Avatar
Did you replace the sending unit yet?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 06-15-2016, 08:26 AM   #16
solidaxel
solidaxel's Avatar
Yes, what a PITA !
LS 3 4L70E
Old 06-16-2016, 08:44 AM   #17
solidaxel
solidaxel's Avatar
O K, all looks like everything is working
This the coolest time we are going to have for a few months and no alarm this AM
The new gauge is now reading what the Aux. analog one was reading a few days ago, before the sending unit was changed 40#
LS 3 4L70E
