LS Airbox
Thought I'd share my air box.
95-97 chevy truck under hood storage box with "ram air" opening in core support and temp sensor relocation.
'69 C10 | LS2 | 4L70e | 4 Wheel Disc Brakes | Accuair eLevel | 20" steel wheels | Porterbuilt goodies | Push Button Start | Tilt | Cruise '79 Burbo | 2wd | 8100 Vortec/Allison swap | A/C | soon to be bagged. |
Re: LS Airbox
Double Duty, I like it!
Are these in all pick ups?
Re: LS Airbox
Thanks! I think they are in just about every truck and suv. Some of the diesel trucks had 2nd batteries in that location.
I really wanted to find something GM to use and this popped in my head.
meowMEOWmeowMEOW
Re: LS Airbox
cool setup. Fwiw, thats called a "bellmouth"
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Re: LS Airbox
I always called them turbo mouths because they are often seen on turbo cars. Bell mouth sounds better.
#6 | |
meowMEOWmeowMEOW
Re: LS Airbox
Re: LS Airbox
TODAY, find a truck box from a 95 to 97 Chevy truck !!
Re: LS Airbox
Also added a gasket to the lid and a clevis pin to hold it tight.
Boosted Member
Re: LS Airbox
Killer looking ride. Love the stance.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq 1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift 1964 Buick Skylark Twin TURBO 383 LS pro-touring project 2014 VW Passat TDI - Daily Driver Turbo diesel 2015 Sierra Denali HD Duramax Turbo diesel 2023 Ford Explorer ST - Twin Turbskis 2023 Ford F150 RCSB - Whipple Supercharged 2017 Polaris RZR Turbo 2014 Nor-Tech Center Console - Twin Supercharged Outboards TURBO ALL THE THINGS!! |
Re: LS Airbox
Thank you. I am really happy with how it turned out.
Re: LS Airbox
Here is a shot through the grille.
Re: LS Airbox
What is the proper name of the truck box............. for ebay info
#13 | |
Re: LS Airbox
Daddydan717 is who I got mine from
Re: LS Airbox
Looks like your using a custom rad with inlet outlet on the same side ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#15 | |
Re: LS Airbox
Summit racing. Couple hundred bucks
#16 |
Re: LS Airbox
Thanks, I will try that
#17 |
Re: LS Airbox
heres mine
used the stock hose, with a K&N on the end. sawed off the big empty square on the stock hose cause it was hitting the radatior covered the hole with a data plate i took from a abandoned coal fired powerplant in Greenville SC now gotta figure out how to get the AC compressor on |
#18 |
Re: LS Airbox
I wonder if that box would make a nice home for the ECU and relays needed for my upcoming LQ9 swap? Seems like the right location for the typical truck harness. I remember this box in my 96 K1500 well!
#19 |
Old member
Here is mine.
4" hole cut for the air to enter the box. ![]() 4" coupler to mount the ninty and box and K&N filter. ![]() The caddy box with another 4" hole cut and coupler installed. I sealed off the factory opening. ![]() Box installed with the ninty and a bracket I made. ![]() This is how it looks done. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#20 | |
Re: LS Airbox
#21 | |
Re: LS Airbox
I'm sure it would. Would be a nice way to hide all that junk. I chose to use it as an air box so I could do the ram air thing. All of my electronics are under the seat with amplifiers, relays and the push button start box. It was just too much to squeeze in there and not stress the harness connections.
