06-16-2016, 10:03 PM | #1 |
1966 C10 w/factory air possible swap to aftermarket system
I have a 1966 C10 with factory air. I am thinking about swapping it to an aftermarket system. Does anyone have any suggestions on the system they have personally used? I really want to keep the dash looking the same as it does now and use the original vertical slides and pull knobs.
Thanks in advance for the info. Posted via Mobile Device |
06-17-2016, 09:50 AM | #2 |
Re: 1966 C10 w/factory air possible swap to aftermarket system
Vintage Air SureFit will do the trick, your dash will look OE.
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
06-18-2016, 08:14 AM | #3 |
Thank you 65Gregg.
06-18-2016, 01:19 PM | #4 |
06-18-2016, 01:35 PM | #5 |
06-18-2016, 04:21 PM | #6 |
when you do the vintage air it has 4 outlets so I created some outer dash side vents that have a factory look. plus nsb29 makes the inside dash air box that will work with the vintage air.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
06-18-2016, 05:20 PM | #7 |
Winston is always on the hunt.
It only has original paint once |
06-18-2016, 05:58 PM | #8 |
