Old 06-17-2016, 06:12 PM   #1
RestoreAmerica
How do you install gas tank grommet
Hello,
What is the easiest way to install the gas tank grommet?
Thanks!
RestoreAmerica is offline   Reply With Quote
Old 06-17-2016, 06:33 PM   #2
Elliot949
Elliot949's Avatar
Re: How do you install gas tank grommet
The easiest way is to pull the tank... But pull the seat... cut the old one out... you will need a trim tool... and alot of patience and pull it through...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 06-17-2016, 07:13 PM   #3
flashed
If your tank is already installed lube your new grommet with dish soap and it will work in with a little hand work .My first one did not last long and I did not want to remove the tank when I got a good grommet.
flashed is offline   Reply With Quote
Old 06-17-2016, 07:18 PM   #4
Lanman1972
Lanman1972's Avatar
X2, all I had on hand was WD40, cut the old one out and slid the new in. No problem, don't need to remove the tank.
Lanman1972 is offline   Reply With Quote
Old 06-17-2016, 08:50 PM   #5
ole dollor
ole dollor's Avatar
still either way it is still not easy ........ good luck
ole dollor is offline   Reply With Quote
Old 06-17-2016, 09:08 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Cut the old one out, lube the new one with wd40 and pop it in. 5 minute job.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-07-2018, 01:29 PM   #7
davepl
davepl's Avatar
Make SURE your replacement is good. I was never able to find a suitable grommet for my 1970 402 Longhorn and wound up reusing the original even though it was a fairly high end restoration. I glass beaded it and turned it upside down, razor blade trim and tire shine spray, looked close to new!
But if I had cut it, I'd have been hooped! So just make sure...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 06-18-2016, 02:29 AM   #8
ksshane
ksshane's Avatar
X2 on the dish soap.
I used a screwdriver to carefully work it in to place. Keep it soaked in dish soap and it only takes a few minutes
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 02-06-2018, 02:49 PM   #9
stevenfromtexas
stevenfromtexas's Avatar
silly question
......tank grommet orientation.....
cone "in/down" or cone "out/up"???
Steven
'67 SWB, 250ci, 3OTT.......this is my first build......
I wonder if my grand kids will say, "I would give anything to have my grand dads 2005 Chevrolet Z71"
stevenfromtexas is offline   Reply With Quote
Old 02-06-2018, 03:27 PM   #10
cleszkie
cleszkie's Avatar
Warming the grommet up in the sun a bit first never hurts either. Makes it a tad more pliable.
cleszkie is offline   Reply With Quote
Old 02-06-2018, 03:37 PM   #11
CG
BlahBlahBlah
What is this Sun you speak of?
Hopefully your grommet is a good quality one like Wes sells at Classic Heartbeat. Those grommets are sooo nice, and pretty darn easy to install.
Old 02-07-2018, 05:53 AM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
X2 on using gaskets from Classic Heartbeat
http://www.classicheartbeat.com
Keith
Convert to disc brakes.
Old 02-06-2018, 03:37 PM   #13
Lanman1972
Lanman1972's Avatar
Maybe for you CA guys!
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Old 02-06-2018, 06:27 PM   #14
Rich69shortfleet
Originally Posted by stevenfromtexas View Post
silly question
Cone out/up.
Rich69shortfleet is offline   Reply With Quote
Old 02-06-2018, 10:05 PM   #15
stevenfromtexas
Originally Posted by Rich69shortfleet View Post
Cone out/up.
thank you brother!!
Steven
Old 02-07-2018, 10:59 AM   #16
Keystone_Hate
Man, I just tried doing this yesterday with the tank in. Lubed up or not, warm, cold, whatever... it is a pain in the neck to do with the tank installed. I got the grommet from Wes at Classicheartbeat and it is solid heavy duty rubber. Not the squishy pliable stuff from the parts store. If you can, remove the seat and tank. Put the grommet in, then slide the tank through it. I used windex to lube it up. After 30 minutes of trying to poke the new one in place with a screwdriver i just pulled the tank.
Keystone_Hate is offline   Reply With Quote
Old 02-07-2018, 01:11 PM   #17
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
In addition to dish soap or something like, seems to me a heat gun is in order.
I've heard that though the company claims otherwise, typical WD40 is bad for rubber, because "it contains petroleum distillates (paint thinner)". You're likely fine, but I try to avoid it.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 02-07-2018, 01:39 PM   #18
leddzepp
Moderator
leddzepp's Avatar
Classicheartbeat sells replacements that have a warranty
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-07-2018, 03:27 PM   #19
cleszkie
cleszkie's Avatar
Warming the grommet up in the sun a bit first never hurts either. Makes it a bit more pliable.
Well, at least remove the grommet from your sub-zero garage and bring it into your house for a few hours before trying to work with it! I forget about the rest of the world when I'm basking in the sun out here in SoCal.
Old 02-07-2018, 03:27 PM   #20
sick472
sick472's Avatar
For those of us without much sun these days...boiling it in water for a minute will do the trick and won't risk scorching it. Don't forget your gloves!
AND 71Chev... is right, no petroleum based oils just to be on the safe side. Soap or synthetic oil//grease only. Petroleum will speed up the decomposition process.
He who is without oil shall throw the first rod. Compressions 8.7:1
1972 C10
1976 C10 (parts truck)
1985 K20
sick472 is offline   Reply With Quote
Old 02-07-2018, 03:37 PM   #21
leddzepp
Moderator
leddzepp's Avatar
I used wd40 on it almost 10 years ago. Rubber hasn’t deteriorated yet
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-07-2018, 08:25 PM   #22
71CHEVYSHORTBED402
Word is it takes a little over a decade, then toast.
Tony
Old 02-07-2018, 08:37 PM   #23
leddzepp
Moderator
leddzepp's Avatar
I guess I’m hosed
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-07-2018, 11:17 PM   #24
custom10nut
custom10nut's Avatar
Following. Doing this in the near future
custom10nut is offline   Reply With Quote
