Old 06-21-2016, 10:12 PM   #1
MikeyInMarin
I think I just F-ed my truck
Long story short: I was hauling a load of PT lumber up my driveway to replace the lagging on my retaining wall. I heard a bang just after starting up my driveway; it didn't stop the truck and I kept on going to where I wanted to unload the lumber. I thought it was the tailgate (the tailgate was down as I was hauling 12-ft lumber). I found that it wasn't as soon as I tried to open the door. Both the driver's and passenger's door won't open
The tailgate was fine - it must have been the trailer hitch instead.
So the bed was pushed into the cab. And that would happen via the frame. F-ed, no?
There is a long and tortured back story of the unhappy tale of my truck and my driveway. The driveway is steep and 60-ft+ long. The truck would lose traction/control both going up and down the driveway.
I assume I'll have to sell the truck for parts (unless somebody wants to use a truck that can only be entered via the window). It runs fine - the buyer could even drive it away.
I haven't taken it to a body shop; I don't think they'ed give me good news.
What do you think?
69 GMC 1/2 ton long-bed, 350 TH400
MikeyInMarin is offline   Reply With Quote
Old 06-21-2016, 10:18 PM   #2
kwmech
Re: I think I just F-ed my truck
I think maybe a picture is in order
Old 06-21-2016, 10:35 PM   #3
jerry moss
Born Psycho
jerry moss's Avatar
Originally Posted by kwmech View Post
i think maybe a picture is in order
x2
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 06-21-2016, 10:40 PM   #4
jeffahart
jeffahart's Avatar
No, it's not the frame. Probably not doom. Probably a poorly attached bed got pushed into a poorly attached cab! Get under it and look at how it's mounted. Get under it and bench press the bed and cab. Rotten rubber and mounting points. I think.
White K20
jeffahart is offline   Reply With Quote
Old 06-22-2016, 12:11 AM   #5
MikeyInMarin
OK.
Can you tell me exactly what you want a picture of?
The cab has crumpled where the bed hit it. The gap between the door & the cab is larger at the top than at the bottom.
Old 06-22-2016, 12:57 AM   #6
12secondnova
12secondnova's Avatar
X2 on the pictures. If the frame is junk you can find good frames on craigslist for cheap. Just swap the body if the rest of the truck is ok. Sounds like your cab will needs some work though. Pictures of the cab to bed gap and the frame will help people on here who know their stuff with body work help you out.
12secondnova is offline   Reply With Quote
Old 06-22-2016, 05:29 AM   #7
swamp rat
swamp rat's Avatar
If its an original California truck i would say rotted cab and radiator mount bushings and loose bed bolts.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-22-2016, 02:51 PM   #8
crakarjax
crakarjax's Avatar
If it's a wood bed, then when the woods rots out the entire bed can shift because the mounting bolts are then loose -- pretty poor design there. Same thing happened to me when a mover backed my truck up into a garage overhang.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 06-25-2016, 05:44 PM   #9
MikeyInMarin
So here are the pics:
Maybe the frame is OK.
Old 06-25-2016, 06:14 PM   #10
MikeyInMarin
And one more which was missed before:
Old 06-26-2016, 12:41 AM   #11
12secondnova
To me it looks like the bed just shifted forward a split second and whacked the cab hard. Even the gap between the cab and the bed looks good other than the dents. It must have moved your door jam forward just enough to squish the door so its wedged shut. I would get someone to kick on the inside of the door while you pull from the outside on the handle to get it open. I think thats where youre going to see what you will have to fix. And if all that fails paint it orange with an 01 on the side
Old 06-26-2016, 04:39 AM   #12
dazza
dazza's Avatar
and don't forget the flag on top! - it wouldn't be the same without it.
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
