ls fan 2 issue
My fan #2 is not keeping a constant ground he keeps pulsing fan 1# is fine any suggestions thank you
![]() ![]() Join Date: May 2015
Re: ls fan 2 issue
I had problems with my fan 2 as well..turned out to be that the truck ecm was only designed to run one fan..they had to redo something in the program to make it run 2 fans..
![]() Join Date: May 2005
Re: ls fan 2 issue
Yep..... give that man a cigar, said early tunes missed that. Apparently they are using an AC control signal that is not constant
Re: ls fan 2 issue
I told the guy who did my harness I would eventually put ac that's most likely why its doing it? Will I be ok if I ran the second fan to fan 1 wire? If I understand correctly its just a negative wire
Re: ls fan 2 issue
Its a relay trigger ground, so you can wire in a second fan relay and have it triggered by the fan 1wire.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Re: ls fan 2 issue
Thank you for the responses I just wanted to make sure I don't screw anything up in going to run it like that till I get the ac hooked up
