06-28-2016, 03:42 PM | #1 |
Turbo gentlmen
What are your opinions on this? I'd rather have a dart block Callie's crank and better efi. Seems affordable, more than nre and Steve Morris. My truck will be street only backed by a t56 magnum. From what I see I'd just have to get the turbos headers and Intercooler. Anyone know any turbo builders ?
Purgatorio |
06-28-2016, 08:23 PM | #2 |
Re: Turbo gentlmen
How much power are you wanting to make? What fuel are you going to run?
That's one heck of an overkill engine for a turbo build in a street vehicle. Anyway, those injectors are tiny, 62lb/hr is nothing for a boost setup. The Accel EFI is a bit basic. The ad says "up to 1000hp". Heck, for that amount of power just go get a junkyard Gen IV LS and be done with it. Spend your money then on engine management and fuel delivery.
1970 C10 Turbo LM7 5.3/LS6 cam PT7675/4L80E/Holley Dominator EFI/E85 Moser 9" 3.25/4 wheel discs 11.16@121.07 |
06-28-2016, 10:11 PM | #3 | |
Posted via Mobile Device |
06-28-2016, 10:42 PM | #4 |
Re: Turbo gentlmen
I'll let the other folks chime in. But that's flat out a rip-off in this day and age.
Seriously, there are thousands of junkyard turbo LS builds making 700rwhp and living for years. The LS platform is superior for boost in my opinion. I'm sure thats a great engine, but for nearly 18k that's just an absurd way to go about a turbo build. Even if for some reason you're opposed to using a junkyard engine, there are plenty of builders out there who can do an LS long block much more cost effectively.
06-28-2016, 11:00 PM | #5 | |
06-28-2016, 11:28 PM | #6 |
Re: Turbo gentlmen
I remember reading in your build and seeing the pic mocked up with the smallblock and remember you saying turbo as well..I'm not gonna knock anybodys engine combo choice but I remember wondering to myself why you wernt going LS with a nice of a build as youve got going....if your wanting 700hp I have to agree with the above about using a ls/turbo combo..much cheaper to get there with LS and doesnt have to be junkyard..but that's just me..
06-28-2016, 10:08 PM | #7 |
Re: Turbo gentlmen
Any reason you are going with a sbc vs an LS? More wondering than anything. I plan on doing a turbo build on my LS swap eventually.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
06-28-2016, 11:43 PM | #8 |
Re: Turbo gentlmen
Heck I have most the parts room put together a 400" boost ready ls long block. Was going to sell for $7k. Perhaps I should raise the price....
------Motor---------------Bottle 60'---1.53---------------1.41 1/8---6.58 @ 105.92----5.87 @ 118.41 1/4---10.38 @ 126.97----9.24 @ 142.49 |
06-28-2016, 11:46 PM | #9 |
Re: Turbo gentlmen
And I value all you guys Input thank you
06-29-2016, 12:11 AM | #10 |
Re: Turbo gentlmen
Yeah that's the bad part..that you had it smallblock mocked..you could still go ls..it would be fine with the t56..I don't know how far along you got with your frame fab but if it was me I would remove all the mounts and redo them to fit a LS/t56 rather than adapt it to fit..so that would mean some more fab work..but it would still probably be cheaper than doing the smallblock the way you were headed..with the bonus of a more modern engine and some decent gas mileage..I know what you mean though. I looked for a cheap LS block for mockup and can't find one.. but mine will be LS and I'm heavily considering turbos..but under the hood turbos will be a tight fit so I'm thinking about mounting them in the bed..nebs has a good looking setup with his bed mounted turbo on about page 11 of his build.http://67-72chevytrucks.com/vboard/s...d.php?t=380212
06-29-2016, 12:15 AM | #11 | |
07-13-2016, 08:28 AM | #12 |
Re: Turbo gentlmen
The package you have in the first post seems more than enough to do 700HP at the rear wheel. But it does seem overpriced IMO, but it does have a lot of good parts in it. If you are going to make over around 750 HP with a small block, an aftermarket block is a must. As is forged internals and good heads. If you have compared this to Steve Morris and NRE, you have looked at some of the better builders. If you want something less expensive, look to see if Blueprint Engines has something you could work with.
As for LS engines- yes, a junk yard LS engine CAN make 1000 HP- a few times on a dyno but not for long as it will dissassemble itself quickly. I have seen a lot of "1000 HP" LS's that can't run 12's in a 3000# car. If you want a fun streetable ride, you really want torque, not HP. I know people don't brag on torque (unless its a diesel), but it is really what you want. If I had $12000 to spend on an engine ( you must have closer to $20K to consider a $17K engine that you will have to add turbos to), I would go with a Blueprint engines 632. 815 HP, 800ft-lbs of torque, pump gas friendly. No turbos required. AND a 30 month 50000 mile warranty! Try to beat that with a junk yard LS! http://www.blueprintengines.com/inde...ssed-ps6320ctc |
07-13-2016, 12:02 PM | #13 | |
07-14-2016, 01:43 PM | #14 |
Re: Turbo gentlmen
Thinking thru the turbo idea from a financial stand point with an LSX 376:
LSX376 B8 from Jegs, $5600 cam kit with springs: $700 not including labor to install turbos (Precision): $2300 fab inlet side: $1500 estimated EFI: $2000 - this is an under estimation- a Holley Dominator EFI and harness is about this price without the sensors Intercooler: $750 Headers: $1500- better go stainless if you want it to live, will require custom plumbing Intake for an LSX: $600 Injectors: $300+ This doesn't include throttle body, ignition, blow off valve, waste gates and controller and dressing out the LSX with the accessories. Total price so far: $15250. This idea will probably set you back around $20K+. Granted there are several ways you can achieve most any power level you want. If you want turbos then go turbos. They sure look good when the install is done nice and can generate some great power. Plus they are more adjustable than any other power adder. The down side is the excess heat generated requires more radiator and the hot side cracks over time. It just seems like a lot of work and money for something you just want to putt around in and look at and not use to its potential. |
07-14-2016, 05:23 PM | #15 | |
Re: Turbo gentlmen
Purgatorio |
07-15-2016, 03:37 PM | #16 |
Re: Turbo gentlmen
Hmmm... I can go from 520rwhp to 620rwhp to 690rwhp to 810rwhp to 900rwhp in a matter of minutes with my N20 set up.. I'd call that easy to adjust..
07-15-2016, 04:54 PM | #17 |
Re: Turbo gentlmen
Lol that's a good one.... I want to get something to hold togather for your first number...
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
07-16-2016, 01:41 AM | #18 |
Re: Turbo gentlmen
It's not too hard to build a solid trouble free 400" ls motor that will make 500rwhp. I recently did a stock bottom end 5.7 with small 228/236 cam that made 462rwhp @ 5,800rpm with 440ftls of Tq. It just takes a well thought out combo.
07-18-2016, 11:06 PM | #19 |
Re: Turbo gentlmen
07-20-2016, 07:54 PM | #20 |
Re: Turbo gentlmen
Gm LS9 aluminum block, Callies magnum crank, "billet steel Oliver rods" je forged Pistons. The heads seem a bit pricey to me... They are gym but they port them .. Titanium valves. 417 motor sports makes a killer 2000hp intake/intercooler. He has 350 units out with no complaints of heat soak. I'd go with a btr stage 3 turbo cam. This set up is around 17500
Purgatorio |
07-14-2016, 05:36 PM | #21 |
Re: Turbo gentlmen
What about an old style roots blower on a modern LS? This thread has me looking at stuff I cant afford so I'll just post pics of cool stuff I ran across...
07-14-2016, 09:43 PM | #22 |
Re: Turbo gentlmen
Look at the 2 latest Hot Rod Garage on YouTube for them installing two different blown LS's. They do look good.
07-21-2016, 02:12 AM | #23 |
Re: Turbo gentlmen
Lingenfelter is nice but they usually are a bit higher priced for what you get.
TMS has a really good reputation and is probably a better bang for your buck: http://www.thompsonmotorsports.net/p...roducts_id=240
07-21-2016, 01:19 PM | #24 | |
Re: Turbo gentlmen
Purgatorio |
07-21-2016, 01:20 PM | #25 | |
Re: Turbo gentlmen
Purgatorio |
