Old 10-02-2003, 12:03 AM   #1
onelow69
onelow69's Avatar
Exhaust cross over pipe
Just wanted to know the best place to put a cross over pipe in, closer to the headers or closer to the muffler? Also would this make the muffler a little Quieter? What do you guys think.
69 Chevy Truck, 350, 400trans, Lowered 3.5/6, Disc brake conv, All early classic stuff. 62 Chevy Nova 350, 700R4, 2400stall, F9in, 3.70gear, AlburnPosi, Chevelle Disc Brakes, ect.
onelow69 is offline   Reply With Quote
Old 10-02-2003, 12:22 AM   #2
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
I would say about 3 feet from the back of you collectors would be fine. Yes it will be a little quiter also.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 10-02-2003, 12:24 AM   #3
onelow69
onelow69's Avatar
Thanks for the fast reply.
Old 10-02-2003, 12:49 AM   #4
DanoDMano
Pronounced "Pew-al-up"
DanoDMano's Avatar
I had my H-pipe installed to where I could drop the
tranny without having to drop the exhaust.
Classic GM Trucks of Washington Club Member
1970 FS chevy,350/350, Edelbrock cam and intake. Holley 650 carb,HEI,AT,Tangier Orange, 18's,
Power Locks,
Truck Photos
DanoDMano is offline   Reply With Quote
Old 10-02-2003, 12:57 AM   #5
truckster
truckster's Avatar
What I've read, and I'm not claiming to be an expert, is that you should paint a line along the exhaust behind the collector. You run the engine, and where the paint stops burning off is where you put the crossover. I don't know how much difference it makes, though.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-02-2003, 02:59 AM   #6
Injected68LS1
Injected68LS1's Avatar
truckster is right. where the paint burns off is where you want to put the crossover. This is where the highest pressure area is. Ideally you would install an X pipe instead of an H pipe. An H pipe only helps at low rpms. An X pipe will gain you power across the whole rpm range, quiet the exhaust note, and get rid of the droning and the rasp of a 90 degree V8.
Check out http://www.drgas.com/
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 10-02-2003, 09:51 AM   #7
gr8scott51
gr8scott51's Avatar
do a search
Now that Josh has the search feature fixed (thanks Josh), do a search on this subject. Someone had a great reply and included a lot of research on 1/4 mile times and decibal levels. As I recall, the X pipe is the way to go.
good luck, Scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 10-02-2003, 12:56 PM   #8
gr8scott51
gr8scott51's Avatar
the link
http://www.boyleworks.com/ta400/psp/exhaust.html for some good cross over pipe research.
