07-03-2016, 06:05 PM | #1 |
Windshield sealer
What are you guys using to seal the windshield rubber on the outside in the upper and lower corners. I bought some 3M glazing and bedding compound. It is non hardening so the rubber can be removed later if needed. Am I on the right track or should I use seam sealer?
07-03-2016, 06:22 PM | #2 |
Re: Windshield sealer
Are you sure it leaks ? If it's not leaking don't fix it ,If so flow grade windshield sealer
Why is the rope still in the gasket ? Your going to need to fix that split in the top of the gasket .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-03-2016, 07:13 PM | #3 |
Yes, it was leaking when I bought the truck. I put the 1/4" rope under the gasket to tape it off for painting. Didn't want paint on the gasket. I'll pull the rope out as I run the sealer around the windshield that way it will get under the gasket and seal her up. The upper corners have quite a bit of gap under the gasket, it's the original and I didn't want to pull the windshield out.
07-03-2016, 07:18 PM | #4 |
Flow grade sealer? The 3M stuff flows fairly well and never gets hard. That partial tube in the pic is at least 5 years old and still flows out with the caulking gun.
07-03-2016, 07:25 PM | #5 |
Have you looked with a flashlight up under the dash to see if the leak is coming from the body seam or bottom of the windshield frame they rust in those areas frequently .
07-03-2016, 07:36 PM | #6 |
Yes I repaired a rusty area on the pass. side and found no rust on the driver side. I used seam sealer on both sides top and bottom in the joints before I painted the top and cowl/firewall.
07-03-2016, 09:43 PM | #7 |
Try this: http://www.adventurerv.net/par-bond-...ar-p-6859.html
I have a small RV manufacturer who swears by it, he has outlasted Gem Top here in Oregon. |
