To narrow or not to narrow
As my build is progressing I am constantly thinking about traction.
A supercharged 6.0 with 255/65/16 tires is certainly a recipe for disaster! Being that the truck is a step side that is all the tire I can fit under it, I certainly don't want to tub the truck out, but I am considering some midifications to the frame and bed to be able to squeeze some more tire under it. I'd like to see some pictures of "mini" tubbed trucks or trucks modified to fit a wider tire! What do you guys think? |
The 60-66 GMC/Pontiac guy....
Re: To narrow or not to narrow
I run a Mickey Thompson 29X15.00R15LT on my stepside. Only mod to the frame is the bump stop bracket is cut off.
Tucks right under with the correct differential length and wheel offset. And it hooks hard.. :-)
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
It's Better With Nitro
^^^ This...I was just going to point you in his direction.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
Id this too extreme for ya?
My Build: 57 Chevy Pro-Street |
![]() Join Date: May 2012
Stock frame with a step side. I cut the rear end four inches on each side.
![]() Used stock fleet side bed tub's on the step side. ![]() 540 ci motor ,close to 800. Hooks ok with the 16.5 wide MT drag radials. ![]()
Go Fast and Have Fun.!! My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185 |
#6 | |
#7 | |
I found some really nice wheel tubs, they are on order now! I am thinking I will be able to run a 315 tire with these after the install and removing the bump stops! http://ruttersrodshop.com/images/F93682280.jpg |
Plenty of room for tires here:
This is a work in progress:
We left the frame alone, save for removing the bumpstop brackets. I narrowed the stock '65 12-bolt by 7", installed Moser "big Ford" ends, JB5 drums, etc. The wheels shown here have 1" less backspacing than the final wheels (3.5" vs 4.5"). ![]() ![]() The front of the wheel openings were stretched forward 2", both to provide clearance for a larger diameter tire and to center the tire in the opening. ![]() ![]() We formed round stock to the shape of the wheel openings, then cut, rolled, and welded the stock flange to it. That gained another inch of width clearance on each side. ![]() Lastly, the tubs were each widened 5-3/4". ![]() ![]() Current status: ![]() ![]() |
