Old 07-08-2016, 12:44 PM   #1
chbracke
Junior Member
Gas Tank Breathers
Well, I have the same issue that a few other guys have had which is that I've got a new tank in my '70 K5 all hooked up and functioning properly but I don't have the charcoal canister setup at all and when I fill up, I get gas spilling out from underneath the truck. My issue is that the breather lines are way too short (like about 12" each) and so when gas gets going out of one it pretty much has a siphon effect and keeps on pouring. I want to solve this by running longer vent lines but I'm not sure where to run them to (where to mount the other ends) and what breathers to put on the ends of them. Anyone willing to post a few pics of where their gas tank vent lines bolt up to the frame or elsewhere? Any ideas would be much appreciated!
chbracke is offline   Reply With Quote
Old 07-08-2016, 02:02 PM   #2
A1971Blazer
A1971Blazer's Avatar
Re: Gas Tank Breathers
Do you have this set-up at the rear on the opposite side from the fill neck?
My '70 has this but also has about 4 or 5 rubber lines directly below it under the bed.....I filled it up and gas started pouring out...all of the rubber was dry rotted and cracked. I replaced them and that stopped the leak(s).I do have the EVAP canister but I still haven't figured out what all these lines are supposed to do?
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 07-08-2016, 02:51 PM   #3
chbracke
Junior Member
That's an interesting looking apparatus, If I had to guess I'd say it has to do with the EVAP but it'd be just a guess. All I've got coming out of the tank other than the filler tube, sending unit wiring and fuel lines are the vent/spillover tube that runs up to the gas filler inlet and then a breather on both the drivers side and the passenger side.
Old 07-08-2016, 03:26 PM   #4
A1971Blazer
For sure........I've been to two world's fairs and a goat f***in and I've never seen anything like it....
I suppose that some '70s had an EVAP and some didn't....I always thought that the pollution stuff didn't really start until '72......? but I've been wrong before..
So which line is the fuel coming out of?
I would tend to think you need some kind of rollover type vent...
this is interesting because I'm getting ready to fab myself a larger tank with an EFI set up.....
I'm not sure if I need to retain that jungle gym back there or just get rid of it..?
1967 C10 Step side
1968 C10 Step side
Old 07-08-2016, 04:34 PM   #5
hemi43
hemi43's Avatar
Yeah, I learned something new too ! My 70 doesn't have those vent tubes on the opposite side. My vent tube exited right by the filler neck, which would make the tube about 3 feet long. I tried to post a pic but couldn't find one, sorry.
hemi43 is offline   Reply With Quote
Old 07-09-2016, 11:02 AM   #6
4oldcars
4oldcars's Avatar
My 71 Jimmy has a replacement tank installed by PO. Don't know what filler neck was used. I put new rubber vent lines which run to a "collector" next to the filler. Four lines in, one line out. A single line would go from there to the front canister under the battery which I do not have. The single line goes thru the floor and stops. It is open and clear. It takes forever to fill the tank because I must run the gas pump at slowest possible rate or it clicks off. I hope this info is helpful to someone and if anyone knows why mine won't take gas, I'd like to know. I suspect the filler neck?????
4oldcars
Driving:
1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado
The ones I let go:
1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed
4oldcars is offline   Reply With Quote
Old 07-09-2016, 12:03 PM   #7
Glenco
Funny I am just getting to this part of the project also and my hard lines to the vent stack on the drivers side are all rusted out. Has anybody had problems with just running a vented cap and plugging all the other vent tubes except for the filler tube breather??
Glenco is offline   Reply With Quote
Old 07-09-2016, 12:41 PM   #8
hemi43
hemi43's Avatar
That's exactly how they come from the factory when there's no emission controls, vent pipe and fill pipe.
Old 07-09-2016, 11:23 PM   #9
Glenco
Thanks Hemi43 I wasn't looking forward to replacing all those steel lines that had rusted out on me!
Old 07-10-2016, 08:54 AM   #10
hemi43
hemi43's Avatar
NP !! Just remember to run a vented cap.
Old 07-10-2016, 10:40 PM   #11
bigdon-70blazer
Never saw that on my 70.
bigdon-70blazer is offline   Reply With Quote
