Old 07-08-2016, 09:45 PM   #1
DJ_Baar
Parts/Tools for Eaton H052 '67 Chevy C20 3/4 ton
I have found videos on line with YouTube (like this https://www.youtube.com/watch?v=dRhkYQsAKI4 ). And talked to local NAPA, they have thin wall large sockets but no idea what size, I need to tell them. Chevrolet Truck Chassis Service Manual only gives their tool designation, "J-2222" for example. If you have any part numbers or reference I can find with Supplier it would be GREAT. Help
DJ_Baar is offline   Reply With Quote
Old 07-08-2016, 11:32 PM   #2
projectking
projectking's Avatar
Re: Parts/Tools for Eaton H052 '67 Chevy C20 3/4 ton
https://www.google.com/search?q=j+22...&client=safari
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 07-09-2016, 08:29 AM   #3
DJ_Baar
So J-2222 is correct for #/4 ton Chevy/GMC PU's? My question is because I have only seen (via videos) what looks like a large thin wall socket. (I did order another repair manual last night trying to find better details.) Thank you for that assistance, just trying to sort this out some before I go to do the job.
Old 07-09-2016, 11:34 AM   #4
Shaky
Six in a row makes it go...
Shaky's Avatar
I'm in the market for one also. That OTC 1929 looks like it might work. On Amazon it says it has 8 tangs, but on OTC's site it doesn't specify other than showing 6.
https://www.otctools.com/products/tu...spanner-wrench
Here's a pic of mine showing what happens when you don't use the tool.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 07-09-2016, 12:40 PM   #5
DJ_Baar
Guess I need to pull one of my axles to see what I have? (Got side tracked fixing a tire on wife's Toyota FJ.)
Old 07-09-2016, 02:56 PM   #6
Shaky
Shaky's Avatar
Well - I think Amazon has incorrect info with the whole "8-tangs" thing. My truck has six and the tool looks like it has six. The only remaining question is whether the diameters are correct. I'll probably take the risk and order it...
Old 07-18-2016, 07:58 PM   #7
DJ_Baar
Problem is cannot find GM Tool No. J-2222, but newer versions like J-2222-C.
Old 07-18-2016, 08:13 PM   #8
DJ_Baar
http://www.freedomracing.com/j-2222-...ut-wrench.html
"J-2222-C Wheel Bearing Nut Wrench 1929"
"6-lug type socket designed to fit the locknuts on '46 and up Chevy and GMC 5200 and 7200 lb axles, 9-3/4" DANA 60, C/K, G, Pvans, 9 3/4 in DANA 60, 10.5" DANA 70, 10.5" GM AXLES"
If I read that description this SHOULD WORK, (like Shaky said)?
Old 07-18-2016, 08:15 PM   #9
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Pardon me, but I have to ask: Doesn't the newer tool perform the same task?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 07-18-2016, 08:57 PM   #10
DJ_Baar
That is what I was trying to figure-out Stocker. From what I found with tool description with Freedom Racing - it sounds the same.
Old 07-19-2016, 09:25 AM   #11
projectking
The link I posted is what you're looking for, it has 6 tabs on it.
67 Chevy C10 LWB
90 Mustang Gt
Old 07-19-2016, 09:57 AM   #12
DJ_Baar
Thank you for that confirmation Project King, much appreciated.
Old 07-19-2016, 01:35 PM   #13
projectking
No problem, I would of replied sooner but didn't see your thread till this am.
67 Chevy C10 LWB
90 Mustang Gt
