![]() Join Date: Dec 2013
Long bed frame / cross members
I have a nice straight long bed manual frame coil spring , .373 rear good trailing arms ,drum brakes $350.00
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 08-11-2016 at 06:41 AM. |
Re: Long bed frame / cross members
Ttt
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
Ttt
Ttt
zzz
id love the trailing arms . a lil poor at the moment but shoot me a price to 13354 see if I can swing it somehow
#9 | |
I have seen the spring mounts go for anywhere from $25 pair (pitted) to $50 pair for pristine (minimal pitting and straight) - I'd be good with that range.
I'm looking for ones that are straight (mine got bent from corrosion forming between them and frame) and good thickness/no severe pitting. Pics would help if you have any. Just so we are on the same page, the z shaped brackets below are what I'm after..they attach the shock crossmember to the frame from below (riveted to frame and crossmember) ![]()
1971 Chevy C-10 Currently is rust repair |
I'll do $50 + shipping for a clean set , if you want them pm me a phone #and I'll send pictures
PM sent...thx
#13 | |
1 Set of spring perches sold to reb162 $58.00 shipped ,Thanks ![]()
ttt
#15 |
#16 | |
#17 |
#18 |
thanks
#19 |
If you part it out, what do you want for both (L and R) Rear Upper Spring Mount Perches/Brackets and are they in good shape? These are the brackets on the underside of the shock mount crossmemebr that connect the crossmember to the frame.
Thanks! -Bob
#20 |
Make me an offer I can't refuse ...I have a few parts frames and a ton of pieces , Whats the going rate today ?
#21 |
A guy with a truck
Price for a shock crossmember and panhard crossmember shipped to 84015?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#22 |
Yes I have them I'll have to check shipping costs
#23 |
do you have a rear frame crossmember? the 4x4 frame I just picked up had been pulled with a chain sometime and is bent badly. shipping zip is 23150 Thanks Dennis
69 custom camper special 4x4 1969 K5 blazer 1972 short step 4wd factory air gmc |
#24 |
Yes I have a few , I'll have to check shipping costs .
#25 |
need both rear coil spring plate or perch for 1968 1/2 ton truck. do you still have. Greg
