Anybody build there own exhaust using these?
Do these things work pretty good? No leaks or anything bad like that? I'm putting together a new exhaust for my truck to replace the old 2 1/4" that's on it now
Re: Anybody build there own exhaust using these?
Pic
My 2006 GMC Envoy has one of those on it. It's been good for 200,000 miles.
Yes
I had about a $900 exhaust on my SRT4 and after about a year the flex pipe started tearing which of course caused a exhaust leak. I'm not saying yours automatically will but they do tear. So good luck my man
Boyd -67' C10 SWB FLEETSIDE LS 5.3 4 speed muncie ![]() |
Brand quality may differ. I have seen one on a stationary Cummins with a solid mounted vertical stack on a sawmill. Must have been 4 or 5". I noticed it shaking into a Z shape at idle and a good bend at balls out. Can't say much for how long it lasted but definitely high abuse for sure
-Cody |
This is what I was expecting because the thing is almost too good to be true lol
Used one on my work car to replace the factory pipe was $171.00 or buy flex joint & cut & weld in for $24.00. Guess which one i chose to do...still good after 6 months & 14k. Miles...they have these @advanced , auto zone etc.
![]() Join Date: Dec 2013
Where would you need to use these on your exhaust ?
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
![]() Join Date: Jul 2015
Yea you shouldn't need a flex pipe in your system, rubber mounts on your hangers and you're good to roll.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
They are not a bad idea,certainly not nessacary.
I'm sure they will help too keep those header bolts good and tite. Quality matters here. I had bought two when I built my exhaust since my headers exit at slightly weird angles I figured these would help with that. But I didn't end up using them anyway and returned them. They were store brand like walker or something and not good quality either.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
I'm planning for 3" and I'm not sure really how I'm going to route it yet. I was thinking of cutting a hole in the crossmember to keep the pipes high up off the ground but I don't know how I feel about that yet
3" is too much try 2 1/2 , lots of guys cut thru the cross member
Building your own exaust can be a lot of fun and rewarding. There are a lot of different options on how to route it on these trucks depending on what drivetrain you have. Before you decide what your going to do, I would evaluate everything to make sure you get the most from your exhaust. What engine do you have? What is your goal for this project? 3 inch may be too big and disappoint you.
1972 GMC C20 Custom Camper 350/TH350 |
#15 |
as others have said, brand quality makes the biggest difference in how long they last. While you can use them in your exhaust system, im not sure the need you would have for them on your truck. the reason they exist and are used is for side mounted engines on fwd vehicles. the idea is that engines rock side to side under acceleration and a solid exhaust system would break over time or the first time you floored it depending on the vehicle. These flex pipes allow the engine to move while limiting movement of the exhaust system. On a rear wheel drive vehicle like our trucks, rubber lined steel hangers are more than efficient in allowing the needed flexibility.
#16 |
https://www.summitracing.com/parts/wlk-36516/overview/
theses are what i recommend for exhaust hangers. they have a clean look to the system without a bunch of pipe clamps at every one, and last the longest in my experience. this is all i like to use on all the custom exhaust i do in my shop. all while providing proper movement for the system
