Old 07-15-2016, 12:17 AM   #1
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
need some stereo install ideas
I want to put a modern cd player in my 65 sub.
... but I don't want to cut up the dash.
any ideas/ pics on how to mount it under the dash?
been looking it over, just not sure where to start and what to start it with-wood, metal? probably not fiberglass, or plastic, since I have no knowledge of working with those materials.
Old 07-15-2016, 04:12 AM   #2
BigDan3131
BigDan3131's Avatar
Re: need some stereo install ideas
I plan to use a marine grade cd player with a remote. In a sububba you might have to build a center console or build a box and use pc fans to supply cool air to it under your seat or a bigger one with the amps under the rear passenger bench.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 07-15-2016, 05:54 AM   #3
notsolo
notsolo's Avatar
Stumbled on this, http://www.northerntool.com/shop/too...3036_200653036 Basic idea is not new. I will probably try to make something similar. I previously I had giant Cadillac 60/40 seat with cd changer under it and tuner in the dash.
notsolo is offline   Reply With Quote
Old 07-15-2016, 07:29 AM   #4
corvettejim1968
corvettejim1968's Avatar
go with a Retro Sound. this way you can install an Ipod or similar device or even a memory stick. holds thousands of songs. I can help with the music i have 71,000 songs on my hard drive. here is my install
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 07-15-2016, 10:28 AM   #5
LVPhotos
LVPhotos's Avatar
The Retro Sound now has a option to mount just the face and locate the body elsewhere. Price comparable to some top end stuff.
Corvette jim your system seems a little dated. I run one Arc Audio 1100 in my DD one 10" sub. The need for all the stuff we use to use is taken care of. I had a hard time changing my mind. Plus is small and powerful.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 07-16-2016, 07:19 AM   #6
corvettejim1968
my system is dated on purpose. I used to compete in the 90`s and Monolithic is considered to be one of the best sounding amps ever made. took me 21 years to find the 5 amps i have. they are from 1984-1991 I have about $5,000 in the system now it sounds amazing. took it to my first competition in 20 years 2 years ago and everybody was impressed. it was a fun day.
Old 07-16-2016, 10:17 AM   #7
LVPhotos
LVPhotos's Avatar
I was saying the complexity you have most would be overwelm with wires. I run one amp controls two dash speakers, front components, rear full range and one sub10 (to show people you don't need 2) and came out with 2 SQL (quality) trophies. Representing shop not thinking I had shot. The new stuff is easy to set up, more so now with a Pioneer 80PRS deck. Amp is small and makes mounting easy, less wiring and most people are not going to a Compatition in a all metal truck.
A simple dash mount Retro Radio, if dash is not butchered like mine, with the possibility to relocate body elsewhere if there is clearance issues, ac or other.
Simply use deck power or opinions of amps. Bluetooth so you can stream oldies, thumb drive to switch between vehicles. A hidden antenna or if standard one still there. Dealer installed gets you warranty.
Old 07-15-2016, 10:33 AM   #8
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Another vote for Retro Sound. Put a Hermosa in my '72 Camino and love it. Looks fairly stock yet has USB port and Bluetooth for answering phone or streaming audio. Way better quality then Custom Autosound.
CD's are so old school. Convert them over to MP3's, throw them on a large flash drive and never fumble with a CD again.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-15-2016, 02:09 PM   #9
Hugh in NC
Hugh in NC's Avatar
Don't waste your time with a cd player. USB drives or Bluetooth are the way to go. I installed a Retrosound and am quite happy with it. Mine is an older model that does not have Bluetooth, I have to plug in my phone with a wire in the glove box. USB lead is also in glove box.
Hugh in NC is offline   Reply With Quote
Old 07-15-2016, 03:33 PM   #10
64shortbox
64shortbox's Avatar
You might try something like I did on my 71 Cadillac Hearse. I also didn't want to cut up the dash. I bought an AM/FM cassette stereo off eBay and then bought an FM modulated 10 Disc changer and mounted the CD changer behind the seat of my Hearse and even on my C-10 I wanted just more than a single CD (the radio was already in my truck when I bought it I would have NEVER cut up my dash) I bought a 10 FM modulated CD changer and mounted it under the seat of my C 10.
http://www.ebay.com/itm/NIB-Vintage-...BXVwjz&vxp=mtr
http://www.ebay.com/itm/PIONEER-CDX-...FXct3R&vxp=mtr
just a thought
64shortbox is offline   Reply With Quote
Old 07-16-2016, 08:40 AM   #11
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
When I was thinking about using a bluetooth amp in my truck. Its hidden and you use a remote to control it. You can play music from your cell phone or ipod.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 07-31-2016, 11:19 AM   #12
txinliner
txinliner's Avatar
I mounted mine in the glove box using a plastic bracket from a newer style chevy truck ,I used blu tack to adhere the bracket and didn't cut a thing
65c10 43,000 original miles ,230 stovebolt,powerglide,3" drop spidles 3" drop springs w/ half coil cut and 5 drop springs in back with 1 1/2 blocks... c notch soon to add hei offy 4 v intake and holley 390
txinliner is offline   Reply With Quote
