Old 07-17-2016, 06:28 PM   #1
custom10nut
custom10nut's Avatar
Dome light removal?
How does one remove the dome light housing without destroying it? I have figured out that it is not held in with screws. Are there clips that keep it in place? I think I had it out once before, but with my TBI, there're somethings I don't remember. Frustrating. I have a newer model light with map lights to put in, but I don't want to destroy my original. Thanks in advance
custom10nut is offline   Reply With Quote
Old 07-17-2016, 10:46 PM   #2
custom10nut
Re: Dome light removal?
Anyone know?
Old 07-17-2016, 10:48 PM   #3
Gromit
I have this issue too in my 1970 C10..
I suspect the previous owner may have glued it in but I cannot tell for sure.
The cover pops off but the housing will not budge
Gromit is offline   Reply With Quote
Old 07-17-2016, 11:06 PM   #4
custom10nut
Yeah same here. Mine is loose but I haven't taken the time to figure out. Like I said before, I'm thinking that the housing is held in place with clips like all the other lenses in the truck.im going to get a better look at it tomorrow, so I'll let you know what I find out.
Old 07-21-2016, 02:02 PM   #5
oldgreen69
oldgreen69's Avatar
Not sure how to describe, but there is a "push in pin" type of thing, 1 on the left and 1 on the right sides of the base. These push into holes that are in the cab at the ends of the Rectangle hole that the light base sits in. The "pins" are hollow and split with a "head" on them that open when they are pushed thru the hole, and hold the base flush. They look like holes on the base, but actually are these pins. To remove you need to squeeze the two haves together so the head will come back thru the hole. Maybe a small screwdriver or dental pick while pulling out? Be carefull, they're plastic and old! Hope this helps
oldgreen69 is offline   Reply With Quote
Old 07-21-2016, 02:06 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
90% of the time the tabs will break off of them when removed. They are really brittle. You can buy replacements.
LockDoc
Leon
Old 07-21-2016, 02:10 PM   #7
oldgreen69
oldgreen69's Avatar
here is a picture of the back side http://www.taillightking.com/images/...tAssy_Good.jpg
Old 07-21-2016, 07:25 PM   #8
Gromit
Originally Posted by oldgreen69 View Post
Thanks OldGreen69! That is very helpful; I'll give it another look.
Old 07-21-2016, 03:43 PM   #9
frenchy51
frenchy51's Avatar
It's a push in sides while pulling kind of thing. I've taken a lot off of parts trucks and have never had one not break. The plastic gets brittle over the years especially in our Nor Ca. HOT climate. New lenses are available and are the way to go...
1972 Highlander PAC B 400BB-SOLD
1974 K5 Blazer-6.0 swap
1974 C20 Long Bed 454
1977 GMC HeavyHalf
several adopted orphans
frenchy51 is offline   Reply With Quote
Old 07-21-2016, 04:52 PM   #10
diggerbob
diggerbob's Avatar
When you get the new housing, it will likely fail to stay put when you hit a bump in the road. I fixed this by trimming of a short length of mechanical pencil eraser and sticking them in the hole of each mounting pin to give them a bit more "bite".
diggerbob is offline   Reply With Quote
Old 07-21-2016, 05:12 PM   #11
diggerbob
diggerbob's Avatar
