07-17-2016, 07:30 PM | #1 |
K&n or airaid
I want to install a cold air intake on my 08 Silverado with a 4.8 and want to now what you prefer
1970 chevy short box c10 factory 402 big block with AC 2008 chevy silverado regular cab short bed lowered 1990 454ss 52,000 miles 5/6 drop |
07-27-2016, 10:03 PM | #2 |
Re: K&n or airaid
I am running a Volant CAI. I ran an Airaid on my 04 I used to have. And prefer the Volant that I have on my 08 GMC. I am running the powercore filter.
Joseph Joe's 69 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543253 1969 GMC SWB-350 SBC 700R4 2013 Ram 2500 CC Laramie Longhorn Edition-6.7 PPEI EFI Live CSP5 5” ProFlo Exhaust |
08-22-2016, 02:42 PM | #3 |
Parts and more parts
Re: K&n or airaid
Look into the air cleaner setup that Banks sells. It is a good design and controls the "Heat Soak" that many intakes suffer from. I threw my K&N into a swap meet after having it for a year or so. The IAT Inlet Air Temps were really high using it.
http://shop.bankspower.com/c-15-prod...e-systems.html
Frank |
08-24-2016, 12:16 AM | #4 |
Re: K&n or airaid
I would like to post my thoughts about K&N but its politically incorrect. K&N in my mind is basically a window screen with stringy sticky glue sprayed across it. Then the glue fouls the maf sensor, lovely!
A friend complained about poor duramax performance in the summer after a K&N was installed. Opening the hood revealed an open element sucking engine heat not to mention potentially water which is certain death to diesels. I checked another friends stock duramax and looked at his air cleaner assembly and low and behold the factory draws in cool outside air from the passenger inner fender area and a great spot to be nice and DRY!! I guess this isn't good enough for K&N! |
