I have a 69 c10 swb that I am looking to swap to a 5 lug and disk brake set up. I amean also looking to swap the rear end, they are both coil spring. I have a donor 71 that I am going to be using for parts, what all do I need from the donor to complete the swap. Any tips or advice is greatly appreciated. I'm sorry if this has been covered before but I am new to this and this is my first build. Thank you in advance for the input.
Re: Front end and rear end swap
1. Unbolt undesired parts from vehicle.
2. Unbolt desired parts from donor vehicle. 3. Bolt desired parts onto vehicle. 4. Smoky burn outs. |
Are all of the steering components and control arms direct replacement and interchangeable with each other?
![]() Join Date: Oct 2013
Yup its all interchangeable as in change the complete rear and id swap the complete front end with the front cross member (engine cradle ) .Makes it very easy
What are the opinions of the steel A-arm bushings vs the later model rubber bushings?
