Need help. Static drop inner fenders
Lowered my 83 c10 last weekend with a 4.5" front and a 8" rear and it dropped more than that in the front. It sits perfect but driving down the road and you hit a dip the front tires are smashing the inner fenders. I don't want to remove them, looking to cut them and tub them up just looking for ideas on how others have done it. My tires are 235/75/15
Re: Need help. Static drop inner fenders
235/75-15's are almost 29" tall (approx 28.8"). You're going to want to shoot for 27-28" tall max when dropping over 4".
225/70-15 = 27.4 (approx) 235/70-15 = 27.9 Get 2 new fronts & save the current tires for use on the rears @ a later date (or sell them/trade them/etc...).
Diggin The SquareLife
you can remove them an put in trailer fenders in or get some slosh tubz
Be advised, alot of water/debris makes it into the engine compartment on my Square body dually w/Slosh Tubs. While they work, they aren't as good as OE inners @ keeping water/road splash out.
Since I cut the inner structure out on my fenders for the install, my alternative is to modify them (extend several inches) which adds to the cost unless you're a fiberglass/body man.
I want to keep the tire size. I have a few ideas in my head but just looking for some other ideas.
There's a couple builds on here that have stretched their OE inners to allow additional travel.
Do you have links or remember who's builds?
Would limiting the travel with different snubber height be an option?
Seems that would only change what hits what (@ least that's all it did for me).
What about block inserts for the springs. Will stiffen the ride but should stop the bottoming out
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
