07-19-2016, 03:23 PM | #1 |
1941-46 Radiator
I am looking for a new aluminum radiator for my project. I have a very bad original and it looks like the filler is on the passenger side and on top. All the aftermarket units all have the filler pushed toward the engine. Doesn't that hit the radiator support rods?
Has anyone found a radiator that fits correctly? I am running a sbc and 700r4 Thanks for any help
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 |
07-19-2016, 05:56 PM | #2 |
Re: 1941-46 Radiator
All I can tell you from my experience is the Champion Radiators that they claim fits the 46's.......DO NOT! The cap hits the cross braceing comming off the firewall. Its an easy enough fix. The other thing you might have to do is have the filler neck turned 180 degrees as the coolant overflow nipple points towards the drivers side of the truck. You can have Champion change the oreintation of the nipple but I think it cost me about 75 bucks, and they did crapy job of it. Not sure if you have checked out my build but I chronicle all this over on the pre 46 projects side of this site.
07-19-2016, 07:07 PM | #3 |
Thanks Paintman. I was looking at your project and your fix looks very clean to me.
I will order a radiator and now know what I am in for.
07-19-2016, 09:56 PM | #4 |
Hey Doc! Just as a side note. If you do go with the Champion radiator, the good news is, it will bolt directly into the stock radiator core support. It's just all the other B.S. you will have to deal with
07-20-2016, 12:42 AM | #5 |
Take a look at PRC radiators, I will say that they keep the engine on the thermostat here in the desert and it has been a "bit warm".
It stays within 10* with the A/C on in traffic I wish the Vintage Air worked as good as the rad and fan! I am sure others will work but we only tried this one and it works...................get out your wallet!!
07-20-2016, 01:07 AM | #6 |
That looks great. I found a company called superior radiator. USA made in aluminum with correct fitting and filler locations for 270. plus shipping.
Found them on ebay. raddas is there tag name. I will post how it works out when I get it. Thanks for the responces
07-20-2016, 01:07 PM | #7 |
07-23-2016, 05:09 PM | #8 |
We also make radiators here in the USA using domestically sourced materials by hand. They are all tig welded, no epoxy or glue either. Plus, we are a site sponsor. We don't currently make them for the 41-46 models, but we do for the 47-87 models. We'd be interested in building a prototype and would cut a deal in exchange for sending us your rad, and then test fitting the prototype. Let me know if you are interested.
08-07-2016, 01:36 AM | #9 |
Thank you for the info. I had already ordered one. Good to know that you can make them too
08-07-2016, 01:49 AM | #10 | |
Re: 1933 Plymouth Radiator
What does something like this run?
08-07-2016, 05:59 PM | #11 |
email pictures and details about the set-up (dimensions as well) to sales@rndfabrication.com and I can quote you. Typically, custom one-off radiators are in the $475-550 range, but it really depends on complexity / size / etc.
08-11-2016, 06:07 PM | #12 | |
