bigblock73 I need help 10-03-2003, 05:37 PM
79BIG10 Yes you're right that's the... 10-03-2003, 06:57 PM
bigblock73 So ALL/EVERY screw that holds... 10-03-2003, 07:54 PM
swervin ervin Some of the bezel screws go... 10-04-2003, 06:34 PM
10-03-2003, 05:37 PM | #1 |
yeller
I need help
I was just trying to remember in my head how our dash bezels go together...
If I remember right, the circuit board mounts first, then the gauges, then the black metal piece, the lens, and then the bezel right? If so...does the dash bezel bolt to the green/blue circuit board AND the actual metal dash??? If so on that...does anyone have an unbroken curcuit board? It doesn't have to work, it just has to be a complete piece I can use to mount my new dash assembly to the dash. I hope this makes sense...TIA! -Jeff |
10-03-2003, 06:57 PM | #2 |
I'm back with 2nd truck!
Yes you're right that's the correct order. The dash bezel mounts to the metal on the lower right by the radio cutout, and to teh opposite side on the driver side by the vent then the other 2 are on the stteirng column part. There are the 4 holes there but one on each side is for bezel and other for under metal plate. Why do you need a new circuit? I thought you added new gauges? It doesn't need any to mount to the dash.
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
10-03-2003, 07:54 PM | #3 |
yeller
So ALL/EVERY screw that holds the dash bezel on bolts to the actual dash then? If so, then I do not need the circuit...I just thought that some of the screws went to the circuit board therefore I would need it only for mounting purposes.
Thanks brandon. -Jeff |
10-04-2003, 06:34 PM | #4 |
You get what you pay for
Some of the bezel screws go in the green gauge cluster. You do need the green cluster to mount your stock bezel. All the screws on top go into the cluster.
Mike 1985 Chevy C-10 |
