![]() Join Date: Jul 2016
SM465 transmission crossmember
Can someone confirm whether or not the late 60s and early 70s SM465 with a cast iron bell housing used a trans mount? I was thinking that set up used mounts on the bell housing and the SM465 bolted to the back of the bell housing without a rear mount. Thanks, RM
Restoring it $200 at a time...
Re: SM465 transmission crossmember
The crossmember runs under the front of the SM465.
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
Just to make sure I understand correctly, the transmission doesn't use a mount. It is bolted to and supported solely by the bell housing. Correct?
Correct
Thanks! I am working on a 62 4wd and the truck has been highly modified. I am installing a 350 and an SM465. It has a divorced Rockwell T221N transfer case. http://67-72chevytrucks.com/vboard/a...1&d=1469061398
