07-20-2016, 04:16 PM | #1 |
235/261 side mounts?
Hi everyone, I need to put side mounts on my 261 to replace the front mount since I am swapping the crossmember and installing a power steering pump in the spot where the horseshoe mount goes. Is there any mount that will bolt on with some modifications or should I just start from scratch? Thanks
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution Last edited by 62stepside longbox; 07-20-2016 at 04:22 PM. |
07-20-2016, 04:23 PM | #2 |
Re: 235/261 side mounts?
Also found these on eBay, I could build something similar if there are no bolt on solutions
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
07-20-2016, 07:35 PM | #3 |
That pick looks like its off a 55-59 truck. The engine is a 235 and it will fit but the problem is the frame. 60-62 have wide frames and the 55-59 are not as wide. You might have to modify the mounts. You can order it and try it out to see if it will work.
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
07-20-2016, 10:20 PM | #4 |
John, I was going to make ones like that from scratch not buy them so I don't have to worry about them not fitting, just copying the design. I'm thinking that 3/16" plate will be good enough
07-21-2016, 06:35 PM | #5 |
That should work fine.
07-22-2016, 09:50 PM | #6 |
235/261 Automatics used the side mounts. Maybe Ebay has some. When I put a 235 in my 63' I made a template and had a fab shop weld a plate to some 250 side mounts (We cut off the side that mated to the 250). Good Luck
