07-22-2016, 11:40 AM | #1 |
14 bolt rear drum brake issuw
I'm looking for suggestions/answers to an issue I'm having with the rear drum brakes on my Corp. 14 bolt rear drum brakes. I "think" I know what the issue is , but want to put this out there for other possible suggestions that I haven't considered. The main issue is that the rear brakes will begin to increasingly tighten up after just a few miles and applying the brakes while "in town" driving. It eventually gets to the point that when I approach to stop at a light the brakes are already slowing the truck down before I've hit the brake pedal. When I put the clutch in or try to "bounce" off the clutch, the truck barely will roll by itself.
In my most recent outing I brought the truck home and immediately raised the rear and tried to spin the wheels forward by hand and it was as if the parking brake was applied, they wouldn't spin in a forward direction, but would spin relatively easily backwards. The ENTIRE brake system is new front to back (lines, master, booster, prop valve, calipers, pads, shoes, springs, drums, etc.). What I believe to be the problem is the push rod between the booster and master is too long which would keep the line pressure up in the system, particularly the rear, disallowing the fluid to fully return to the master cyl. Can any of you verify my belief before I start chasing possible solutions? Thanks in advance for your replies. |
07-22-2016, 05:56 PM | #2 |
Re: 14 bolt rear drum brake issuw
fastest way to check that is crack the bleeder and see if you get presser. one thing that i have seen once and once only was a bad self adjuster. did the same thing. but was one a honda. new self adjuster kit no more problem. dont know why though. could have been for some other car. other then that nothing comes to my mind
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
07-23-2016, 04:48 AM | #3 |
Self adjusters on the wrong side?
07-23-2016, 07:36 AM | #4 |
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
07-23-2016, 02:26 PM | #5 |
Windy Corner of a Dirty Street
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
07-23-2016, 08:32 PM | #6 |
user # 2756
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
07-25-2016, 02:10 AM | #7 |
Checked the bleeder and all of the brake hardware before I submitted the post. Thank all of you for your input. Found the problem and resolved it. Turned out to be an issue with the new, aftermarket intermediate parking cable purchased for the truck.
