Old 07-22-2016, 05:11 PM   #1
70STOVEBOLT
70STOVEBOLT's Avatar
S/S big block shorty headers on ebay
Anybody bought these or know anything about the seller?
http://www.ebay.com/itm/351717420525...%3AMEBIDX%3AIT
Says they are 16 guage with 3/8 thick flanges. Any info would be appreciated.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 07-22-2016, 07:28 PM   #2
ho70
ho70's Avatar
Re: S/S big block shorty headers on ebay
not good feedback-seems to good to be true
ho70 is offline   Reply With Quote
Old 07-22-2016, 08:29 PM   #3
70STOVEBOLT
I saw the negative feedback, but nothing pertaining to that specific item. A lot of good feedback also, so not sure?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 07-22-2016, 11:00 PM   #4
jeh
jeh's Avatar
It would be worth $104 just to see if they fit!!! I was out more than that with trying to get headers to work with my BB combo!!!!
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 07-23-2016, 09:40 AM   #5
70STOVEBOLT
Jason, what headers did you end up using?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 07-23-2016, 05:15 PM   #6
jeh
jeh's Avatar
I ended up using Sanderson BB8, they are kind of a shorty header. I have POL tubular engine mounts also, the fit was nice but the only thing I don't like is how close the collector is to the oil filter, makes changing oil a bit of a pain in the rear!!!
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 07-23-2016, 05:49 PM   #7
custom10nut
custom10nut's Avatar
$104 for Stainless BB headers? I paid $145 for painted SB headers locally, and that was at a discount. Proceed with caution. That's either a deal of a lifetime, or a colassal waste of your money. Also, will they clear the frame in your truck?
What kind of return policy does this place have if they don't meet the expectation?
custom10nut is offline   Reply With Quote
Old 07-23-2016, 10:49 PM   #8
seafoam68
seafoam68's Avatar
JEH, with the Sandersons, I notice the driver side collector seems to point straight down. Will this allow the pipe to bend enough to run parallel with the frame? I can't stand to see headers and pipes hanging down below truck. Thanks
seafoam68 is offline   Reply With Quote
Old 07-23-2016, 11:13 PM   #9
jeh
jeh's Avatar
I bought the angled collectors from Sanderson, with a tight mandrel bend welded to it works out nice. All my exhaust is tucked inside the frame, if you get down at ground level and look under you can't see anything....
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 07-24-2016, 10:22 AM   #10
70STOVEBOLT
That is my goal also, I don't want to see the exhaust hanging down, Jason, what did you do for trans linkage? I don't want to have to modify the linkage.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 07-24-2016, 11:30 AM   #11
seafoam68
seafoam68's Avatar
Thanks. That is my goal,to have it inside frame.
Old 07-24-2016, 12:30 PM   #12
jeh
jeh's Avatar
That is my goal also, I do t want to see the exhaust hanging down, Jason, what did you do for trans linkage? I don't want to have to modify the linkage.
I "HAD" a 700r4 in mine, ended up being toast at around 500 miles. As far as the linkage I used the kit from Lokar, it worked out nice. I also cut 4" holes and welded in a pieces of 4" pipe in the crossmember that the trailing arms bolt to to keep the exhaust hid even more.
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
