Truck is running hot and can't figure out why
So my 2000 Silverado is running hot, replaced radiator 8 months ago, replaced water pump today, replaced all heater and water hoses and still gets hot don't know why, checked oil and it's clean, not milky like signs of a blown head gasket, it will run about 10-15 minutes and it will get up to 260 temp. It has fan shroud and every thing stock and can't figure out what's going on
Re: Truck is running hot and can't figure out why
It's blowing the water out through the water tank reservoir, thru the hose
![]() Join Date: Sep 2015
Thermostat?
"Orange Crush" |
I've changed it out already
blood type; Retumbo
what temp is the coolant actually? Is the gauge reading right? The stepper motor in the gauge could be off. A scan tool might be of some help
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Pressure test the cooling system. Just because the oil is O.K. doesn't mean that the head gasket is O.K., only that it didn't blow into the oil system. Look for a cracked head or block.
What engine do you have? Early 4.8 had a porosity/crapulence issue with the Castech heads. Don't know if 5.3 uses same head. |
