Old 07-27-2016, 07:27 AM   #1
OLDCHEV4X4
OLDCHEV4X4's Avatar
NP205 paint
I was paging thru the np205 rebuild thread at the top of the forum, and it looked like the inside of the case was painted. Was this intentional, or just a messy painter at the factory.
If it was intentional, what kind of paint would hold up to constant hot oil immersion?
Im rebuilding a 205/th400.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 07-27-2016, 11:44 AM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: NP205 paint
Did a little more surfing and it looks like Glyptal, Armature paint, electric motor paint all would do the job.
But that still leaves the question... is it painted inside intentionally ?
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 07-27-2016, 12:52 PM   #3
snj8198
snj8198's Avatar
Re: NP205 paint
This is what I use. It helps oil drain back and fills rough and uneven surfaces without cracking and chipping.
http://search.eastwood.com/search?w=Glyptol
Engine enamels should work as well for a little cheaper. I've used them in the past without any real issues to report. I think they can flake easier tho without a real good surface prep. Surface prep being a darn good washing and zero oil residue. Leave the casting rough for bite. Some like to polish the surface smooth which does not help the "bite" for the paint. Also, brush on only, toss the aerosol can.
Where's the link to your build? It's been a while since I visited it. I remember you have an enjoyable build.
Steve
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 07-27-2016, 01:28 PM   #4
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: NP205 paint
Steve
Build? Did I do a build thread? Ive been on this forum a long time, i might have did one. I did do some race reports. Special k did some race reports too.
I saw Eastwood has the Glyptol and that is with in driving distance to me.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 07-27-2016, 01:50 PM   #5
snj8198
snj8198's Avatar
Re: NP205 paint
eh, maybe it wasn't a build thread rather just some odds and ends works I had read through the years. memory escapes me.
ya, the Glyptol is a little pricey but works well.
Steve
Old 07-27-2016, 02:13 PM   #6
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: NP205 paint
Here's one... http://67-72chevytrucks.com/vboard/s...ighlight=miler
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 07-28-2016, 08:07 PM   #7
Orange Crate
Orange Crate's Avatar
Re: NP205 paint
Why?
http://www.jalopyjournal.com/forum/t...bother.644312/
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 07-29-2016, 07:46 AM   #8
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: NP205 paint
Originally Posted by Orange Crate View Post
Why what?
Why paint it?
Why not paint it?
Or why in the road?
I want to know if GM painted them intentionally... or sloppy employee with a spray gun.
I dont think quick oil return was the idea for painting them. Maybe keep sand and loose cast iron in place. Or maybe it was to keep the inside of the case from rusting in case of water infiltration. Or .....maybe....the foreman's son with no skills needed a job.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 07-29-2016, 05:02 PM   #9
Orange Crate
Re: NP205 paint
Well I thought the link was self explanatory, meaning no they weren't painted intentionally and why choose to paint the inside anyway.
Old 07-29-2016, 07:58 PM   #10
Re: NP205 paint
There is a good reason for Glyptol, to aide oil in draining back to bottom to be picked up again, rather than slowly because of rough cast surface. It's up to you if it's worth the bother. I don't think GM went to the expense for us. It's an over and above improvement that many, including gm bean counters, will say is not worth the bother. I say, if it's torn down and cleaned up, why not?
Old 07-30-2016, 06:54 AM   #11
andrewmp6
Re: NP205 paint
When nascar told smokey yunick he couldn't port and polish the heads he used that Glyptol paint and it worked.
Old 07-30-2016, 07:24 PM   #12
Orange Crate
Re: NP205 paint
Wow, Smokey Yunick painted Glyptol in his 205? My God no wonder he was so F'n fast....
Old 07-31-2016, 08:39 AM   #13
Re: NP205 paint
I'm not in the race, so I ported and polished my transfer case. Glyptol is for sissies!
Old 07-31-2016, 11:19 AM   #14
snj8198
snj8198's Avatar
Re: NP205 paint
hahahhaha hehehe
Steve
