07-27-2016, 08:57 AM | #1 |
viar compresoor ?
I have a viar compressor, I can,t remember the model # but is a 33 percent cycle.I was wondering if it too much to handle a 3 gallon tank especially when the tank is empty.I not much into going up and down all the time.I have a slow leak somewhere and gets empty in 4-5 days and I don,t drive it that much
07-28-2016, 02:00 AM | #2 |
Re: viar compresoor ?
There should be a sticker on the motor housing. Is there a model or part number listed?
08-08-2016, 11:45 AM | #3 |
Member of the longbed union.
If you have either the 400 or 420 model number you will be good, with are the only 2 33% duty cycle compressors they sale. You will be good with just having the single compressor. It has a higher CFM rating then the 100% duty cycle ones. I would try to find where your air leak is and fix it. You have to remember that when you are filling it from empty you need to let it sit for awhile after it fills the tank to cool down. Also remember you need to drain the tank fully atleast once a week to drain any water that gets in the tank if you don't have water traps.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
