Oil Pressure Line Question
Installed a new 350 engine in my truck and the oil pressure line doesn't seem to fit anywhere on the engine or the hole is a different size. Is there an adapter or something I can use so I can still have my oil gauge work?
My original line: |
#2 | ||
"I ain't nobody, dork."
Re: Oil Pressure Line Question
That part of the fitting fits inside the fitting that screws into the back of the block. The one that fits in the block I believe is 1/8" NPT and that part at the end of the copper line fits in to that.
Don't start your new engine without anything in that hole in the rear of the block or you will have oil EVERYWHERE! ...ask me how I know... ![]() Gary
#3 | |
Do you happen to have a link to the one that I would need? Thanks. |
#4 | |
![]() Join Date: Jun 2012
Hmmm...i did that once too. Guess where the oil went? All over my brand new medium blue carpet....it took alot of scrubbung and different chemicals and even more cussing, but i got it all out finally
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
Here is an adapter: http://67-72chevytrucks.com/vboard/showthread.php?p
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#7 | |
Here is a photo but this is not as good as SWB4x4 because I don't know the part number or where to buy.. Maybe Ace Hardware too; theirs are all non-lead fittings now and they are more expensive than the automotive versions that are still okay with lead content in the bronze...
If you have the dual dipstick block make sure your dipstick tube hole in the block (opposite of wherever you put the dipstick) is plugged with that little steel plug.. passenger side or drivers side..No offense I hope but I just have read about so many people missing that.. |
Try again: http://67-72chevytrucks.com/vboard/s....php?p=7455766
Edit: and from another of LockDoc's threads: "The male end is 1/8" pipe thread and the line fitting (compression sleeve nut) screws into the other end."
#10 | |
I guess I'm not the first, second, or third to have accidentally run the truck without the gauge connected! I got lucky in that it landed on a floor mat, though.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
![]() ![]() Join Date: Jan 2005
I spent quite a bit of time last night searching through old posts trying to find information on the engine block adapter. I headed over to Napa today and they sell them. Their part number is 6200x2.
Male Connector - 1/8" Tube O.D., 1/8" Male Pipe Thread https://www.napaonline.com/en/p/WH_6...rdInput=6200x2 |
The Older Generation
#14 | |
