door switch / dome lamps
Hej,
I am currently trying to repair the dome lights at my 79suburban. Right now there are now light and also no voltage in the socket. My way was: I have found these little switch in the driver door frame. is this the "ground"switch for the dome light? does it work like a "breaker"? i asume that I have to switch the (car) lights on and the knob should be in the left / fixed position, right? next: i have checked all fuses - but maybe - the fuse isnt there (under the dashboard) - how is the fuse called??? (cigarette lighter is the same fuse as the HORN) would be great to get some tipps ![]() thx in advance, stephan ps: i know the thread "http://67-72chevytrucks.com/vboard/showthread.php?t=481653" Last edited by paintinx; 08-09-2016 at 11:37 AM. |
![]() Join Date: Mar 2016
Re: door switch / dome lamps
There should always be some voltage in this line. Sounds like a line cut or bad ground.
hello again - i got the solution today by trying something.
here for all users with the same question the whole story: 1st, I measured the electricity from the switch in the drivers door. result=white cabel - it is GROUND door closed - no ground, door open - ground 2nd, I opened the covers inside the drivers door, found some rust and measured ALL cabels - and as a few thread describes - "cable can be broken" - it is/it was. (look at the photos I took) 3rd, I replaced all cables from drivers carpet till the B pillar (there is a connector inside the b pillar - watch if it is ok and not "corroded" 4th, I got it ![]() thx, stef
2 kids, 2 cars Sub2k - 5.3 ltr vortec Sub79 - 7.4 ltr big block Das Schiff ist im Hafen sicher, aber dafuer nicht gebaut. |
another question re dome lights
what would be the best way to get two new lamps
for my suburban? the older ones are very corroded ... stef
Tags |
fuse |
