10-05-2003, 11:26 AM | #1 |
MY TRUCK IS FOR SALE!!
and yet another question from me
Currently on my truck I have a quadrajet (rochester) with an electric choke that I have no idea where to plug it in at.....
On tuesday I am gettin my Edelbrock carb with an electric choke.... and I have no idea where it is supposed to be hooked up at.... Anything will help... thanks
1979 Chevy LWB 350ci / 700R4 Edelbrock under the hood F O R S A L E OR T R A D E |
10-05-2003, 12:16 PM | #2 |
If I remember right that choke wire is a key-on 12 volt line.
It heats the choke coil to keep your choke from being on all the time. |
10-05-2003, 12:17 PM | #3 |
Project92 SWB stepside
Correct run it to a switched 12v source and it will be fine.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
10-05-2003, 12:44 PM | #4 |
You get what you pay for
The power for the choke comes from a wire which is hooked to the oil pressure switch. You should have a oil pressure sending unit and a switch. The switch is the two pronged one.
Mike 1985 Chevy C-10 |
10-05-2003, 01:08 PM | #5 |
Wiring for electric choke
Wiring for an electric choke should be done carefully. Connecting additional electrical loads on the ignition system is not a great idea. To easily wire any electric load, use a small cube relay. The relay may be controlled by the ignition wire connected to engine coil. The relay is a small electric load. The power for choke thru relay should come from a seperate fuse and battery source. A 10 amp fuse will be correct for the electric choke.. Use a stranded wire size of at least 16 gage.
Chevy stepper 400sb 350 turbo |
10-05-2003, 01:15 PM | #6 |
What Frank-id said is probably a good idea because choke heaters pull quite a load.
10-05-2003, 02:36 PM | #7 |
THank YoU
Thanks guys for so much info....
Is that all I need to know? Where would I get that relay from? Is it on my truck already? I think I saw one on my firewall.... Or do I go to my local auto parts store and get the wire and fuse and relay? Thanks again for the help!!
10-05-2003, 05:55 PM | #8 |
Da relay
The relay may be procured at many many places. I'm poor and get most parts at the salvage places. The best relays are from an electrical company named Bosche and made in Germany. These relays are found in all european cars and trucks , especially VW. Vdub has the good relays. At a salvage place the relays are about a buck, however the relays can be gotten at Radio Shack $6.95 or a big rig truck shop for just $9.95. Many stereo shops also sell for about $4.95. There are many many choises. Oh yeah, Ebay often has relays for $2.50 each in lots of 10. The inline fuse is at all the places noted.
There are also several relay rated amps and switching configuration as single pole or double pole. Single pole will work on choke nicely. The amps ratings are usually 30 or 40 amps at 12 volts.....
10-05-2003, 06:40 PM | #9 |
frank, whats with the pic
10-05-2003, 07:24 PM | #10 | |
10-05-2003, 08:38 PM | #11 |
Early in this chain, Swervin made a point which was overlooked --
The choke is often hooked the the OIL PRESSURE switch. This prevents a key-on no-start condition from warming up your choke and making things REALLY hard to start. That is, of course, if your vehicle is older than about '74 and has an electic oil pressure guage. Brian |
10-05-2003, 08:42 PM | #12 | |
Where would I find the "OIL PRESSURE switch"? Thanks
10-05-2003, 08:57 PM | #13 |
It will be low on the drivers side rear of the engine, just above the oil filter.
Brian |
10-05-2003, 09:01 PM | #14 |
Thanks Brian!!!
And thanks to everyone that gave me a little insight!!!
10-05-2003, 09:16 PM | #15 |
Brian,
you noticed that too? If your truck originally came with an electric choke, it will have a OP switch and a OP sending unit. The sending unit will have one prong which goes to the gauge. The switch is made specifically for the choke. 12 volts goes to the switch and if the engine has oil pressure, it lets the 12 volts go out the other side to the choke. As Brian said, it is so the choke won't heat up with the engine not running. My 85 has both of them beside the distributor in a brass tee. You could have one or both there. Or you could have the switch above the oil filter and the sending unit beside the distributor. If you don't happen to have a switch, it's easy enough to buy one at Advance or somewhere and add it. This is the proper way to hook up the electric choke. I have no idea where the relay idea came from. It's not needed at all. Mike |
10-05-2003, 09:24 PM | #16 |
And then
Some one said.........what is with the pic??
this pic came from a national magazine called great pics. I like it very much. What are the odds of being able to feed a bluebird a cracker from your hand.... Just another look at some else's life. The electric choke ..... I have some 40 years of being a mechanic among other challenges. Connecting the electric choke to an oil pressure switch is not a great idea. In big rigs, the alternator is controlled by an oil pressure switch to allow the engine to warm toward operating temps before the engine is loaded up with a high amp output. The wiring thru the oil switch was not long lasting and made the choke stay on longer with no engine starting gain. The electric choke mechanical adjustments are unique to the area the engine lives. Here in Idaho, the settings are different than Alabama.Every climatic area has it's own set of adjustments to maximize economy and performance.
10-05-2003, 09:25 PM | #17 |
And in response to you Mike...
My truck came with the electric choke... But it wasnt hooked up... I knew it was always there, but never found out where it was supposed to go or how.... Untill I came here!! Thanks for your time....
10-05-2003, 09:30 PM | #18 |
Alright now I am REALLY confused....
10-05-2003, 11:41 PM | #19 |
Mechanical opinions
Every one who does anything has an opinion. Many ideas are learned thru a history at doing some task and others adopt what another may say. Also involved with decisions is whether to improve a situation or just make it work. My back ground is such that I strive to make any finished job better if possible than found. Most decisions of large companies are based on the dollar. A relay is not absolutely required for an electric choke, but it is a far better method. Even the aircraft world must make some decisions based on the dollar. I guess the only place decisions are not mostly based of money is.......space and weapons. I change lots of wiring, mechanics and ideas trying to have a better.....truck, house,rv,bus,or Vette.
Yep, I'm an old guy, but wisdom just doesn't walk up, ya gotta make lots of mistakes. I'm past the ego and macho thing. I'd like to share some mechanical stuff that worked out good. If the pics annoy you, please look away.
10-06-2003, 12:58 AM | #20 |
I didn't adopt this. It's the way they are from the factory. It's the way my 85 was and is. It works great and always has.
I say do whatever you want to do, but this is the way it is supposed to be.
10-06-2003, 03:15 AM | #21 |
Somebody wired my electric choke to the fuse block switched power. I guess by all the previous discussions is not the correct way, right?
Mitch 1978 Chevrolet Silverado C 10 454 BB, TH400 |
10-06-2003, 03:27 AM | #22 |
Darn Frank-id..............that is a REAL engine
and the low-boy is overloaded, but who cares! Oh yeah......the choke thingy, What I would do.... Find a 12v line under the hood that gets power when the engine cranks, This line I would hook to a pole on the (Bosch) relay, I would take a 12v line from the battery or the junction block on the firewall and feed this to the relay, I would feed the choke with the 12v out of the relay. If you did it this way.....the choke heater would only work when the engine was running, like it needs to. You could include the oil pressure switch like Swervin said......that is how the factory does it.........but it is not 100% necessary. This said........all the above is my OPINION |
