![]() Join Date: Nov 2015
TH350 Modulator Vacuum line for 4x4 pictures
Anyone have a picture of the modulator vacuum line for a TH350 in a 4x4? I bought one from www.inlinetube.com and they say it's for my 71 GMC K15 4x4 but it doesn't look anything like what I have on it now.
Thanks for the help 18Z |
Re: TH350 Modulator Vacuum line for 4x4 pictures
Is this a correct TH350 Transmission modulator vacuum line for a 4x4?
![]() Join Date: Mar 2003
doesn't look correct to me
I think it should have 180 degree turns at both ends. I have one at work
Anybody have a picture of how the right one for 4x4's looks like?
Carpe manana
![]() ![]() Join Date: Dec 2010
Here one I have loose. Will try to compare w one on a k5 this weekend to confirm it matches. Did 4wds use a different line for sure? I can't recall.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
It should be the same line 2wd and 4wd
When I looked around for one, the sites always had 2wd on the listing or both 2wd and 4wd to order, www.inlinrtube.com has both 2wd and 4wd so I ordered the 4wd and it doesn't look like the one I have on my 4wd truck but doesn't look like it would work right either. The one I have on there now gets in the way of my transfer case shifter which is why I thught the PO might of put the wrong one on.
18Z |
Carpe manana
Others have had fitment issues w inline tube products so it wouldn't surprise me if it wasn't 100% correct. Does the 2wd part # differ?
Yes the part#'s are different.
Surely someone on here has a picture of a 4x4 TH350 transmission modulator vacuum line!
Here is a pic of the one I pulled out of my 72 K20, might have a few extra bends in it as I just yanked it out and wasnt all gentle like.
Thanks RedRoad, that looks more like it should look to me, I will send this photo to inlinetube and see what they say.
Thanks again 18Z |
Here is mine out of my '72. Looks a little different that the others in the thread but I'm pretty sure it's original to the truck.
edit to add there use to be a clip holding the modulator line to the dipstick but it's likely under the table.
#15 |
Thanks Everyone, I hooked up the one I got from inline tube and it works but I think I will make my own to make it a bit more streamline.
