Old 08-10-2016, 06:33 PM   #1
dsraven
47-54 door weatherstripping
helping buddy with his 54 gmc. he bought new weatherstripping rubber from LMC and glued it in according to their youtube how-to. the doors will not close, not even close. striker plate is all the way out already. the rubber is too dense and won't compress. seems like he needs a new rubber style or manufacturer. anybody have any ideas? he grabbed a sample of "D" style hollow stripping with 2 sided tape on the back. it is too wide but looks like a narrower strip like that would work if we can find some.
any help would be appreciated. thanks in advance.
Old 08-10-2016, 09:40 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 47-54 door weatherstripping
You most likely have the one on the left and need the one on the right
go over to metro molded parts and look at LP 40-A
Old 08-10-2016, 10:39 PM   #3
iowaboynca
iowaboynca's Avatar
you know, this seems to be the umpteenth complaint about that company's weather stripping. I can't imagine they're not getting complaints as well @ corporate.
Working in QA/QC for a large CPG/beverage company, something like this would be triggering the alarm bells at my company and Sr. Mgmt would be screaming for a solution.
Granted, I have ordered from the mentioned company have have been fairly satisfied with both parts and service, but it seems like this one complaint always seems to surface. *sigh* Done with the rant...
Thanks as always DWCSR for the advice.
Build: "1950" GMC -Charlotte
iowaboynca is offline   Reply With Quote
Old 08-11-2016, 03:35 AM   #4
MiraclePieCo
MiraclePieCo's Avatar
I just went through this also. If you insist on using the original style, get the smaller size from Steele Rubber Products. Universally recommended.
After a failed attempt to use the original style, I gave up and just bought a roll of generic 7/16" square foam self-adhesive weatherstrip from my local home improvement store. I'm happy with the fit and ease of installation.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 08-11-2016, 09:51 AM   #5
dsraven
thanks for the advice guys. we will check those out and see what we can make work. dwcsr, are the recommended ones a lot softer than the other like he has? they seem to be too dense of a foam to squish out.
Old 08-11-2016, 10:44 AM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
I can say if it softer than what you have but its the right profile.
Old 08-13-2016, 06:27 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
The one on the left is 1/2 base width by 11/16 tall. The second one, ( the one I use LP-40-A) is 9/16 base width and 1/2 tall. Its very important that its in the correct orientation or nothing will fit. The door will still be a little hard close but once its set for a while closed it forms the correct fit and after a short while it will close and open like you want.
follow these directions and it should work out for you
https://www.youtube.com/watch?v=SajNpDzRTdU
LP-40 is the heavier seal version of the LP-40-A they are both metros Supersoft seal
Old 08-13-2016, 10:28 PM   #8
MiraclePieCo
Just finished my second door as we speak. Frost King weatherstrip from Home Depot. $30 for enough to do both doors twice. Took about 10 minutes per door. Doors have to be slammed right now, but I expect it to compress. Not feasible for a restoration, but at the price and ease of installation, I'm more than happy.
